  • Page:
  • 1
Ignition key code 1980 kz1000G 27 Mar 2024 06:43 #896954
  • Tolon
  • Tolon's Avatar Topic Author
  • October 14
  • Thank you received: 1
Just picked up a 1980 kz1000g -no keys. Ignition cylinder is stamped “411” so ordered a NOS key for a 411 but it doesn’t fit the cylinder. Looks like it’s for a much older bike maybe? Am I wrong that this is the key code?
1982 kz1000k (my baby)
82 GPZ1100piston/cyl
84 GPZ1100 head/cam
01 sv650 fork swap with cbr F4 internals/gsxr calipers & master cylinder
05 gsxr600 swing arm/monoshock
GM HEI ignition module swap
Full custom wiring and control setup
1980 kz1000g
1995 kz1000p
Ignition key code 1980 kz1000G 27 Mar 2024 12:06 #896970
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Maybe rstnick will chime in.  Partzilla has a photo of a key that should be correct for your motorcycle (I'm assuming the key in their photo is correct for the part number and not just a stock photo). The head probably doesn't matter, but the blade offset is opposite from the key you got.  From the diagrams my motorcycle uses the same key blank (27008-1103).  I got an ilco key KA14..X103 at the hardware store and they used my old key as a template to cut it.  ... www.partzilla.com/product/kawasaki/27008...e0d8bade71be6e496589
Last edit: by martin_csr.
Ignition key code 1980 kz1000G 27 Mar 2024 13:32 #896974
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
It looks like there might be a number or symbol before the 4 on the lock cylinder.
Ignition key code 1980 kz1000G 27 Mar 2024 13:43 #896975
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 384
PM as I understand it no longer is working. Rob would be who I would want to talk to about this. I am sure he will see this at some point and respond.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Ignition key code 1980 kz1000G 27 Mar 2024 18:39 #896986
  • Tolon
  • October 14
That’s the actual key I got. Just tried to crop it so it looked nicer. I was trying to figure out if that might have been another stamping before the 4, but I just couldn’t quite make out what it might be. Almost looks like it could be a K or maybe a 5, but that seems to be a stretch. I’ve been trying to find out the code ranges that might have been in use at that time, but no luck. I have a replacement ignition that is keyed in the 700 range and it fits fine other than the cut. Could it be that it needs cut to the 411 code with the other blank?
Mostly I’m just putting off taking apart the instrument cluster to get the ignition out in hopes that I’m not just missing something simple.
Anyway, thanks in advance. I really have learned a lot from everyone here over the years, not many issues that I have run into that you guys haven’t pointed me in the right direction.
84 GPZ1100 head/cam
1980 kz1000g
1995 kz1000p
Ignition key code 1980 kz1000G 29 Mar 2024 04:19 #897034
  • Tolon
  • October 14
Tried to get a better picture of the cylinder, looks like it could be a 5411? Anyone else see the same?
Thanks!
84 GPZ1100 head/cam
1980 kz1000g
1995 kz1000p
Ignition key code 1980 kz1000G 29 Mar 2024 06:53 #897037
  • Mikaw
  • Mikaw's Avatar
  • Away
  • Thank you received: 1883
Good eye Tex. Tolon I see 5411 also.
The following user(s) said Thank You: Tolon
Last edit: by Mikaw.
Ignition key code 1980 kz1000G 29 Mar 2024 16:29 #897060
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
For that year, I would think it would have a Z5000-6000 key code number.
Could be Z5411
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Ignition key code 1980 kz1000G 30 Mar 2024 11:18 #897075
  • Tolon
  • October 14
Got the seat lock off this morning, it is indeed a z5411. Thank you everyone for the help, now just waiting on my key to show up…
84 GPZ1100 head/cam
1980 kz1000g
1995 kz1000p
  • Page:
  • 1
