  • Page:
  • 1
  • 2
1984 KZ1100R valve cover removal 27 Mar 2024 06:16 #896953
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1897
PS: don't forget to back off the cam chain tensioner before you re-fit
1984 KZ1100R valve cover removal 27 Mar 2024 08:28 #896957
  • CT5110
  • CT5110's Avatar Topic Author
  • Thank you received: 7
Appreciate the intel and advice Mcdroid and I will see if I can find the service manuals....I will need them. I believe the engine is the same as the carbeurated 1983 GPZ1100 and, if so, I can try and find the service manual for that. I am aware of the tank issue and understand that it was repaired. I have been riding it--vs. just showing it and intend to do more once I have the gasket repair done. I am the second owner and had been looking for one for a while but will keep you in mind if circumstances change.//Craig
1984 KZ1100R valve cover removal 28 Mar 2024 06:00 #897002
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
1984 KZ1100R valve cover removal 28 Mar 2024 08:42 #897018
  • CT5110
Download the service manual here:
www.kzrider.com/filebase/download/21-kz1...z100r-service-manual
Thanks Howardhb. I had downloaded previously and I realized after looking for engine specifications that there appears to missing pages in the Base Manual--specifically section 6.5 and above and therefore is missing diagram for bolt removal order for head. At least I cannot seem to locate it within this manual. Whoever copied and uploaded did me/us a favour but it seems they missed some impt pages. I will keep searching and may choose to buy a service manual on ebay if unsuccessful. Thanks again, Craig
1984 KZ1100R valve cover removal 28 Mar 2024 08:54 #897019
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
The 81 - 83 kz1000/1100 manual in the articles section should have what you need as these all use the "J" motor
The following user(s) said Thank You: CT5110
Last edit: by Wookie58.
1984 KZ1100R valve cover removal 29 Mar 2024 10:45 #897046
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
1982 KZ1100-A2
The following user(s) said Thank You: CT5110, howardhb
Last edit: by daveo.
1984 KZ1100R valve cover removal 30 Apr 2024 16:48 #898272
  • CT5110
HI McDroid....I have made progress on the gasket replacement and it was suggested to consider getting the engine painted. It was also brought to my attention that there is a specific 'black' colour that this engine has. Would you happen to know if that, 1) is accurate and 2) if so, where would I find the original colour of the engine. If I am going to do it I would like to get it as close to original as possible. It looks like an enamel paint and I don't think it is powder or ceramic coated.....but I may be wrong.
Thanks in advance.Craig
  • Page:
  • 1
  • 2
