  • Page:
  • 1
  • 2
1984 KZ1100R valve cover removal 26 Mar 2024 11:32 #896910
  • CT5110
  • CT5110's Avatar Topic Author
  • Thank you received: 7
Greetings from British Columbia. I have been a lurker for a while and find the information exchanged overall is really helpful and useful. I have a question related to valve cover removal and the order in which the bolts are required to be removed and replaced. I do not have a service manual and it is the first time that I am doing this to replace gaskets. I am told (I am not a mechanic) that the order matters of bolt removal and replacement is important and I am reaching out for advice. I have downloaded the supplement service manual however the page with the diagram is missing--but who ever uploaded the manual I appreciate what is there. Any advice is welcomed, Craig
1984 KZ1100R valve cover removal 26 Mar 2024 12:04 #896913
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 305
Greetings Craig...so the supplemental KZ1100R manual refers to the base manual (KZ1000/KZ1100, 3rd edition)...(which is posted on this site under the 1000cc category) to address your question.  Go to page 6-15 to 6-17 in the base manual.  The manual does not list an order for either removal or replacement of the bolts (all 24 of them) suggesting that order doesn't matter.  Common sense would suggest that when tightening them, do all finger tight then in a crosswise pattern, tighten them to specs (87 inch lbs.).  Nice motorcycle...too bad we never got it south of the border.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
1984 KZ1100R valve cover removal 26 Mar 2024 12:09 #896915
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1952
Rule of thumb is loosen from the ends working towards the middle and tighten from the middle working towards the end in a "criss-cross" as mentioned
1984 KZ1100R valve cover removal 26 Mar 2024 12:16 #896916
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
Welcome!
Loosening does not require any specific pattern.
Tightening :  Crisscross pattern, starting in the middle, work toward the outside.
Pictures please!
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Wookie58, Rolf1976_KZ900
1984 KZ1100R valve cover removal 26 Mar 2024 14:35 #896922
  • CT5110
The following user(s) said Thank You: Mcdroid, rstnick, daveo, sf4t7, howardhb, Wookie58
1984 KZ1100R valve cover removal 26 Mar 2024 14:36 #896923
  • CT5110
Thanks to you all for the prompt reply. As stated, very helpful forum.// Craig
1984 KZ1100R valve cover removal 26 Mar 2024 14:51 #896924
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Nice...did you recently purchase that bike from a fellow by the name of Glenn?
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
1984 KZ1100R valve cover removal 26 Mar 2024 15:31 #896929
  • CT5110
McDroid.....indeed I did. Bought it a few years ago actually when I was in Vancouver. What do you know about the bike?//Craig
1984 KZ1100R valve cover removal 26 Mar 2024 15:54 #896930
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2726
Hopefully, you plan to adjust the valves while the valve cover is off.
1984 KZ1100R valve cover removal 26 Mar 2024 16:57 #896934
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Sweet bike...he took good care of it and he was instrumental in me getting information on that model (I collect info on different models).  I do remember that he had issues with that tank leaking fuel via some pinholes...which I think he resolved by brazing those holes...and then had the tank repainted.  I am surprised he sold it, actually...but he does have (had) a 1400 Concours.  It will be wise of you to print off or purchase both the KZ1100R supplemental manual (Kawasaki part number 99924-1038-02) and the base manual (Kawasaki part number 99924-1026-03).  There are a few idiosyncratic things about your model, e.g. carburation. Nothing scary. Both are still available on eBay. If you ever tire of the bike...keep me in mind.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: by Mcdroid.
1984 KZ1100R valve cover removal 26 Mar 2024 20:29 #896940
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 239
Don't tighten over 60in/lb is my only advice. The bolts aren't going to come loose. Tighten to 87in/lb you are looking to strip threads.
The following user(s) said Thank You: sf4t7, howardhb
1984 KZ1100R valve cover removal 27 Mar 2024 05:59 #896951
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1635
And in case it needs to be said, torque is in INCH-lbs, not ft-lbs.  you never know sometimes. ha ha.
  • Page:
  • 1
  • 2
