  • Page:
  • 1
Ultimate Carb Kits 08 May 2017 12:58 #761489
  • Jeff.Saunders
  • Jeff.Saunders's Avatar Topic Author
  • Vendor
  • Thank you received: 181
Ultimate Carb Kits
Exclusively to Z1 Enterprises, we are introducing these new superior carb kits containing parts previously unobtainable.
Initially for the Z1, KZ900 and KZ1000 (and some Suzuki / Yamaha models), we plan on introducing more kits in the near future.
With four different needles, needle jet, choke plungers, large assortment of jet and more.... check them out.
www.z1enterprises.com/catalogsearch/result/?cat=&q=nencho
This email address is being protected from spambots. You need JavaScript enabled to view it.
Z1 Ent on Facebook,
The following user(s) said Thank You: GPz550D1, slmjim+Z1BEBE
Last edit: by Jeff.Saunders.
Ultimate Carb Kits 08 May 2017 13:45 #761492
  • undiablo
  • undiablo's Avatar
  • Thank you received: 64
donĀ“t forget kz750! :)
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Ultimate Carb Kits 08 May 2017 21:37 #761524
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Was a link included?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Ultimate Carb Kits 09 May 2017 04:59 #761528
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Click the Z1Enterprises logo at the top left, then search Nencho.
Last edit: by martin_csr.
Ultimate Carb Kits 09 May 2017 05:10 #761529
  • Jeff.Saunders
  • Vendor
The link is the very first thing in the first post.... here it is in full...
www.z1enterprises.com/catalogsearch/result/?cat=&q=Nencho
Z1 Ent on Facebook,
Ultimate Carb Kits 09 May 2017 05:24 #761531
  • martin_csr
Thanks. maybe edit the topic post to underline the link?
Ultimate Carb Kits 09 May 2017 07:00 #761535
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 444
Looks great Jeff. Always a good idea to use a good quality kit, especially when it coems to the carburetors. The cheap kits you see on ebay out there are just not worth it.
However, I found the hardest part to source (couldn't source) was the carbureator shaft seals. Jeff, do you guys carry these seals?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: by KZJOE900.
Ultimate Carb Kits 12 May 2017 06:41 #761815
  • Jeff.Saunders
  • Vendor
Hi Joe, if you are referring to the 1" diameter seals and plugs that are on the VM24/26/28/29 carbs - the ones the linkage rod goes through - we are working on getting these made. We had a source briefly for them, and that company evaporated.
Z1 Ent on Facebook,
The following user(s) said Thank You: KZJOE900
Ultimate Carb Kits 26 May 2017 17:28 #762807
  • Jeff.Saunders
  • Vendor
More carb kits arriving in 2-3 weeks - including in them are kits for the KZ550's with TK22 carbs - so FINALLY you can tune for the 4-1 pipes and pod filters... Do you know how many years I have searched for TK22 parts??? They have been on my wish list for 8-10 years.
Also kits for the early KZ750-B1/B2/B3 twins and KZ1000-J1/J2 models.
Z1 Ent on Facebook,
The following user(s) said Thank You: GPz550D1, KZJOE900, Street Fighter LTD
Ultimate Carb Kits 28 Jun 2017 18:01 #765614
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
Jeff
Check your pm's
1984 750 Turbo
Ultimate Carb Kits 28 Jun 2017 18:21 #765615
  • Jeff.Saunders
  • Vendor
The new keyster kits for the KZ550 TK carbs are in stock now...
www.z1enterprises.com/keyster-premium-ne...kz550-1980-1983.html
In a few more days we'll have the KZ1000J, KZ1000E and KZ750 twin carb kits online too - they arrived in the warehouse, we just need to get all the pictures taken and those will be online as well.
Z1 Ent on Facebook,
The following user(s) said Thank You: GPz550D1, TexasKZ, Street Fighter LTD
Ultimate Carb Kits 30 Jun 2017 14:09 #765769
  • DFIGPZ
  • DFIGPZ's Avatar
Jeff
I will let you know about kits check your pms.
1984 750 Turbo
  • Page:
  • 1
