Kosman frame bracing kits for the Z1 KZ900 KZ1000 07 Aug 2015 15:59 #684821
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
I'm afraid we're on our own.
Kosman frame bracing kits for the Z1 KZ900 KZ1000 09 Sep 2015 15:05 #689378
  • Mcgoo
  • Mcgoo's Avatar
  • Thank you received: 0
If anyone knows of where to find an alternate kit... Even from japan it would be greatly appreciated
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:56 #696426
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
I have been slowly putting my KZ1000 Superbike back together piece by piece. People been asking about frame bracing and where to put all the bracing needed to make the big KZ to handle. The frame picture here is what most people used in AMA Superbike racing from late 1977 to about 1981. All that thin plate gusseting around the steering stem is flat useless. Just remove all of it. Tubular bracing is the only answer to strengthening up the steering stem. Now if you add oversize motor mount bolts, and ream the frame and engine cases so that all the motor mount bolts are a interference fit or press fit. The motor becomes part of the frame. All other gusseting that is not shown is really not needed to strengthen up the frame.
1986 RG500G 2 stroke terror.
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:57 #696427
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:57 #696428
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:57 #696429
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:57 #696430
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:58 #696431
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:58 #696434
  • Dr. Gamma
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 10:58 #696435
  • Dr. Gamma
Sorry about all the duplicates, the library in Prescott Valley just got hit by a HUGE thunder shower, then everything locked up and then went blank. Then all the duplicates popped up.
Last edit: by Dr. Gamma.
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 11:09 #696437
  • SWest
  • SWest's Avatar
  • 10 22 2014
Do you want them deleted?
Kosman frame bracing kits for the Z1 KZ900 KZ1000 29 Oct 2015 11:12 #696438
  • Dr. Gamma
YES PLEASE!!! There should be a total of six photos with the listing. It is getting real scary here in Prescott Valley. The skies have opened up again big time !!!
