Making a key by the code number. 07 Nov 2019 03:38 #813662
  • LoganKX
  • LoganKX's Avatar
  • Thank you received: 0
Hi mate, I have a 82 kz750gt I have to unfortunately part ways with and someone is interested to buy it but I have misplaced the key over time. Can you help me please!?
Cheers
Logan
Making a key by the code number. 07 Nov 2019 06:01 #813666
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1991
LoganKX wrote: Hi mate, I have a 82 kz750gt I have to unfortunately part ways with and someone is interested to buy it but I have misplaced the key over time. Can you help me please!?
Cheers
Logan
You should contact rstnick direct as he may not check in here and see your post
Making a key by the code number. 08 Nov 2019 05:05 #813704
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
A good locksmith should be able to make a key from the code. Also, there are usually keys available on eebbaayy >> some sellers can cut a key using the code which can be found on the ignition switch. The same code should also be on the seat lock & helmet lock, but removing the ignition switch might be the only feasible way to get the code. keys cut >> example EB item # 333089344956
I had a key made for my 81 KZ650-CSR using an Ilco KA14 X103 blank >> it's almost identical to the Kawasaki keys in the pic. Your key may be different.
Last edit: by martin_csr.
Making a key by the code number. 13 Feb 2022 11:48 #862256
  • rstnick
  • rstnick's Avatar Topic Author
  • Thank you received: 376
I am still making keys by the key code number for those in need.
Rob
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: ThatGPzGuy, TexasKZ
Last edit: by rstnick.
Making a key by the code number. 27 Apr 2024 19:48 #898178
  • Kawasakik1e
  • Kawasakik1e's Avatar
  • Thank you received: 8
Hanging some difficulty figuring out how to PM on this forum....
 can you reach out to me? I need keys for my daughters '77 KZ400.
Key code is 7 9 0
Thanks......!!
The Collection-all insured, plated and ridden.
'79 KZ650 EFI/Turbo Project
'76 KZ900 "Workin' Man"
'00 ZRX1100 The Beast
'09 H-D XR1200 "XR8ted"
Last edit: by Kawasakik1e.
Making a key by the code number. 27 Apr 2024 19:59 #898180
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2091
Key code is 7 9 0
Thanks......!!
PM system is broken.
The following user(s) said Thank You: Kawasakik1e
Making a key by the code number. 28 Apr 2024 00:34 #898182
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1899
Rob are you happy for me to share you email with this member looking for keys ?
Making a key by the code number. 28 Apr 2024 07:36 #898185
  • Kawasakik1e
Thank You!
Last edit: by Kawasakik1e. Reason: Deleted my personal email address
Making a key by the code number. 28 Apr 2024 07:58 #898187
  • Wookie58
  • Wookie58's Avatar
  • Moderator
... or if you could forward my email to him? I would greatly appreciate it.
Im at:  This email address is being protected from spambots. You need JavaScript enabled to view it.
Thank You!
No need now you have posted it, the offer was to keep your contact details out of the public domain !!
Making a key by the code number. 28 Apr 2024 10:54 #898195
  • Kawasakik1e
Not worried about my email being public; figured I might speed up the process .... if you would be kind enough to email him directly; he might see an email pop up on his phone faster than him getting around to logging onto this site and seeing a notification..... as he is running a business cutting keys, I don't think he'd mind the help. I might be wrong.
EDIT:  Looks like Rob(Rstnick) had his email posted a bit deeper in this thread.
it is: This email address is being protected from spambots. You need JavaScript enabled to view it.
thanks for any help you can provide!
