Making a key by the code number. 30 Nov 2010 18:07 #414874
  • rstnick
  • rstnick's Avatar Topic Author
  • Thank you received: 376
Here's how I make a key by the code number;
I'm a Locksmith, and have programs for tracing key code numbers.
I punch in the # and the manufacturer into the computer:
Then choose the right series:
The program tells me which blank to use, and how to set up the key machine.
I load the blank into the machine and press start.
Blank on the left, and a cut key on the right:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: kzrider, hemicbx, conghos, eric77kz, Kawasakik1e
Last edit: by rstnick.
Making a key by the code number. 30 Nov 2010 19:20 #414891
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
  • Thank you received: 12
Cool! :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Making a key by the code number. 30 Nov 2010 19:32 #414893
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
  • Thank you received: 75
That's cool! But! The keys look so bland. Is there anyone who makes blanks in the design of the original z1 key?
79 LTD B3
Making a key by the code number. 30 Nov 2010 19:33 #414894
  • JMKZHI
  • JMKZHI's Avatar
  • Thank you received: 48
That Ilco key is what I'm using: KA14 X103.
Making a key by the code number. 01 Dec 2010 18:11 #414984
  • rstnick
Our suppliers don't have them.
You may still be able to get them through Kawasaki, or find some on ebay.
I bought one on ebay thats got a black plastic head with the K logo.
Just make sure the milling in the key is on the proper side, as some are on the right as the ones above, and some are reverse and milled on the left.
Also later model Kawi keys could be thicker in the center area, and not fit/slide into the older locks.
Around 1979 the keys got longer with 6 cuts in them where before that the keys only had 4 cuts.
A longer key can be cut shorter, but a shorter key cannot be made longer no matter how long you rub it. ;)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Making a key by the code number. 02 Dec 2010 05:08 #415023
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Thank you received: 1282
I have a key machine as well but it's not a code machine like yours. I can only copy an existing key.
Actually rstnick turned himself in for advertising but I see his thread as more educational than self promoting. For one thing the technology he's describing is available at most every locksmith shop.
One thing I missed: If you don't have a key. Where do you find the number? Is it on the ignition switch somewhere?
Thanks In Advance
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
Making a key by the code number. 02 Dec 2010 06:52 #415030
  • JMKZHI
  • JMKZHI's Avatar
The code is on the ignition switch on my 81 KZ650. Its supposed to be on the seat lock as well, but I've never looked. I've never seen mention of the code on the helmet lock, so I'm not sure if it would have one or not.
Edit: I checked a nos ignition & lock set: all 3 have the code stamped into them.
Last edit: by JMKZHI.
Making a key by the code number. 02 Dec 2010 19:06 #415098
  • KZQ
  • KZQ's Avatar
  • Administrator
Thanks Guy and to rstnick as well for this very informative thread.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Making a key by the code number. 02 Dec 2010 20:29 #415112
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2089
Might try these folks for some blanks.
www.motorcyclekeys.com/blanks.html
Making a key by the code number. 03 Dec 2010 17:51 #415219
  • rstnick
The key code # will be located in different spots throughout the years.
On my '78 it was right beside the keyhole on the ignition, as it is on most early, Zs/KZs.
In '79 it was beside the seat lock's keyhole.
On others it may be on the side or back of either lock.
It will be in one of the series listed below.
Any other number is probably just a cast in part # or something.
Kawasaki Key codes:
170-174
175-195
176K-250K
251K-325K
3101-3150
3201-3250
326K-400K
401-470
701-720
706-710
751-795
8001-9000
801-845
901-925
A00-A99
B8001-B9000
E8001-E9000
G1-G35
KZ5001-KZ6000
N1-N35
RVS101-RVS499
Z5001-Z6000
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Making a key by the code number. 04 Dec 2010 05:46 #415260
  • Kawickrice
  • Kawickrice's Avatar
  • Thank you received: 18
Thanks for my Suzuki key Rick it works like a charm.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Making a key by the code number. 04 Dec 2010 13:25 #415316
  • rstnick
Your welcome Kawickrice.
Oh, and it's Rob by the way.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
