And finally, Wookie's 82 begins ! 06 May 2024 06:23 #898541
  • Coyote
  • Coyote's Avatar
  • Thank you received: 17
Dude, that is slicker than Owl Poop! Wish I hadn't seen this.... you got me thinking now :)
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
And finally, Wookie's 82 begins ! 11 May 2024 14:28 #898895
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Thank you received: 1896
Still got a couple of small jobs to do on the front end before stripping so I can clean up the frame ready for powder coating (I have pretty much decided those ugly headstock braces need to go  ) first on the list was to get the front fender fitted correctly, in my mind this was going to be a "trim" and four new holes - didn't work out that way !!! The Zephyr brace isn't wide enough for the ZX9R forks, also the brace has bushings that stop the plastic being crushed when the bolts are tightened (so much for a quick job) sorted now so onwards tomorrow
The following user(s) said Thank You: Injected, calum, howardhb, Stereordinary, Rolf1976_KZ900
And finally, Wookie's 82 begins ! 12 May 2024 11:29 #898928
  • Wookie58
  • Away
  • Moderator
Another little job knocked off today, Since I will be using the "sat nav" on my phone I thought a charge point would be useful (too many years in cars) also I wanted some way to be able to plug in an AFR meter for set up that didn't leave wires dangling when not in use so I have gone with a double USB socket. Also made a start on the oil cooler mounts today
The following user(s) said Thank You: Injected, howardhb, Rolf1976_KZ900, Quofan
And finally, Wookie's 82 begins ! 14 May 2024 12:23 #899017
  • Wookie58
  • Away
  • Moderator
Another little job knocked off this evening, oil cooler mounts now sorted (kind of like my alloy bushes) it's a Uni cooler so I know it's suitable for the low pressure motor
The following user(s) said Thank You: Injected, calum, howardhb, Stereordinary, Rolf1976_KZ900, Quofan
And finally, Wookie's 82 begins ! 15 May 2024 02:59 #899079
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Away
  • Thank you received: 130
Its coming together nicely .That oilcooler looks almost similar to the one used on yamaha fj.I dont know what an AFR is
And finally, Wookie's 82 begins ! 15 May 2024 03:24 #899081
  • Wookie58
  • Away
  • Moderator
AFR = air/fuel ratio meter
The following user(s) said Thank You: Rolf1976_KZ900
And finally, Wookie's 82 begins ! 15 May 2024 04:10 #899083
  • Rolf1976_KZ900
  • Away
Aha of cource! then you dont have to take the plugs out 50 times to get the mixture right like i have done the past weeks .
And finally, Wookie's 82 begins ! 15 May 2024 04:18 #899085
  • Wookie58
  • Away
  • Moderator
And finally, Wookie's 82 begins ! Yesterday 11:50 #899242
  • Wookie58
  • Away
  • Moderator
Wrapped up the oil cooler today, I wanted to use the GPZ cooler as I know it flows enough for a "J" motor and I wanted an OEM cooler for the look I am going for (could of always been that way) the issue is the cooler uses flanged couplings and I wanted to use "AN" fittings (not least because OE hoses are not cheap) so back to my trusty little lathe to knock out some adaptors. There is something really satisfying about creating your own custom parts to overcome challenges
And finally, Wookie's 82 begins ! Yesterday 11:58 #899243
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
Is there going to be enough room for the pipes?
And finally, Wookie's 82 begins ! Yesterday 12:15 #899245
  • Wookie58
  • Away
  • Moderator
Funny you mention that Steve   I thought there would be but "not quite" so I need to relocate the steering damper bracket   I guess these bumps in the road come along on a build like this
And finally, Wookie's 82 begins ! Yesterday 13:48 #899249
  • Coyote
  • Coyote's Avatar
Nice looking work, especially the fabrication side. Yep, no matter how much you plan ahead, there's always one little something that catches you and makes you reroute or redesign
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
