KZ1000A1 Spare Parts Project 17 Dec 2021 09:47 #859210
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 394
I tallied up the left over parts from my restomod build and I'm only missing the following parts for a second build:
- Cockpit
- Indicators and headlight
- Tank
Maybe a few other small parts to replace stuff I can't rescue but I've almost got everything I need.
The frame has been straightened and I took the crank to get balanced when I dropped off the restomod frame. When I pick the frame up I'll take the hubs and rims to get relaced. I'll probably do most of the painting parallel to the restomod work. This will be a low budget project - get everything as nice as I can and make sure the engine runs well without replacing parts unless absolutely necessary. Will be trying to restore it to the original state (will have a few repro parts though).
Last edit: by calum.
KZ1000A1 Spare Parts Project 17 Dec 2021 11:28 #859218
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
That statement sounds very subjective to me!
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
KZ1000A1 Spare Parts Project 17 Dec 2021 11:34 #859219
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
FAMOUS LAST WORDS
KZ1000A1 Spare Parts Project 17 Dec 2021 11:45 #859220
  • calum
I know, I know.... I'm gonna try real hard not to spend too much money...
KZ1000A1 Spare Parts Project 17 Dec 2021 13:17 #859229
  • Skidmark
  • Skidmark's Avatar
As with all project vehicles, no mater the number of wheels, it is a slippery slope you are standing at the edge of.  At some point in the process, there is a huge conflict between the desire and the wallet.  Which one wins usually involves a significant other, if you have one!  If you don't have one, the remainder is won by hunger.
Retired gearhead
'81 KZ-750 E2
KZ1000A1 Spare Parts Project 17 Dec 2021 13:53 #859232
  • calum
I have two significant others at the moment. One is sitting next to me on the couch - the other is the restomod project that wants to be the only one I spend my money on ;)
KZ1000A1 Spare Parts Project 17 Dec 2021 15:49 #859235
  • Skidmark
  • Skidmark's Avatar
Glad I am not the only one working on two bike projects at the same time.  And my neighbor's 38 Dodge Bros Business Coupe hot rod.
Retired gearhead
'81 KZ-750 E2
KZ1000A1 Spare Parts Project 17 Dec 2021 16:42 #859236
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Unless you multi tasking your not living. You guys and not the only ones needing an hour on the couch.
The following user(s) said Thank You: Skidmark, Rick H., calum
KZ1000A1 Spare Parts Project 18 Dec 2021 00:26 #859246
  • calum
That '76 is a really nice build - but it needs an engine :)
KZ1000A1 Spare Parts Project 18 Dec 2021 08:48 #859259
  • Mikaw
  • Mikaw's Avatar
Yes it does. Waiting on a crankshaft. I’ve been assembling the last few internal parts while I’m waiting. Other very generous members here offered to help, one was quite a drive and the other offered me up his spare. The latter has a Life rule that two is one and one is none, so I know how important that part is to him. I’m trying to take the path of least resistance and go with a third member that offered one up. He has been on a long trip out of state, he recently caught up with me through email said he was home and was working on packaging so that it can be shipped safely. I am holding out on the last high dollar item that seems to be a very expensive part for its physical size. It is a very important component being the upper cam chain idler assembly . I could buy Liska for cheaper but the nut and bolt rivet counter in me is really pushing back on that . NOS are around $200 plus shipping and that has been a hard nut to crack.
Last edit: by Mikaw.
KZ1000A1 Spare Parts Project 19 Dec 2021 04:21 #859290
  • calum
I bought all new cam chain gears and rollers for my other project and am hoping there are enough good parts from the two engines to reuse on this project. The engine will probably end up costing more than I would like, though. I can always replace/restore other parts that aren't quite up to standard over the next few winters, but I don't want to be going back into the engine for a good while.
KZ1000A1 Spare Parts Project 28 Dec 2021 07:49 #859709
  • calum
Gathered up all the parts for powder coating today. Did the math and was surprised to see that powder coating works out cheaper. The main problem is that I don't have a spray room anymore and need to rent by the hour - not enough room here to just have at it in the garden either.
Ended up with a pile of nuts and bolts etc. for plating as well. Will have to get cleaning sometime soon.
Can anyone tell me what these parts are?
And what this hook is for?
