  • Page:
  • 1
Oil leak 22 Apr 2024 14:38 #897984
  • Tyler_98
  • Tyler_98's Avatar Topic Author
  • Thank you received: 0
Hi everyone, new kz1000 owner so I’m excited to join the community. I have a small oil leak in front of my center stand that is starting to get annoying and was wondering if anyone could help me identify the issue and let me know how hard it is to fix. Any feedback is greatly appreciated!
-Tyler
Last edit: by Street Fighter LTD.
Oil leak 22 Apr 2024 16:40 #897990
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1988
Welcome to KZRider
I fixed your picture to be full size . Next time click the insert all tab to complete the installation .
I would guess the oil is coming from behind the  sprocket . . Take the outer cover off and have a peak
No gaskets needed
Oil leak 22 Apr 2024 17:21 #897991
  • Tyler_98
Okay thanks I’ll remember that for next time, I took the cover off and I think you’re right it’s really dirty behind here. Can I just clean the sprocket and inside of the cover with brake clean and relube the chain? Or is there a different way to clean it up
Oil leak 22 Apr 2024 18:15 #897995
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
It looks like the drip is coming from higher up.  My guess would be one of the seals (not the gasket) in the transmission cover is worn enough to leak a bit.  You can see the seals in this screenshot.  #4, 10 & 11.  Most likely #4.
There is also an O ring seal on the out put shaft and it might be the culprit.  #31 in the second screen shot.
Last edit: by hardrockminer.
Oil leak 22 Apr 2024 18:17 #897996
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1922
Looks like your shift shaft (11), out put shaft (19) or clutch push rod seal (20) is leaking.
The following user(s) said Thank You: hardrockminer
Last edit: by Scirocco.
Oil leak 23 Apr 2024 07:32 #898019
  • Bobf
  • Bobf's Avatar
  • KZ1000A3A
  • Thank you received: 13
4 seal points not including the gasket.
C ShFt o-ring
C Shaft seal
Clutch push rod seal
Shift shaft seal
All can be replaced with out removing the cover. Shift shaft seal is a bit more challenging without removing the cover .
EKKAWI
1976 KZ400D
1977 KZ1000A1
1976 KH400
1979 XS400
1980 KZ550A
1980 KZ750E
1983 GPZ550
1979 KZ1000B LTD
1986 ZG1000 Concours
1982 XS650 Turbo
KZ1000C
KZ1000P
1978 KZ650C (×2)
2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
  • Page:
  • 1
