GPz1100 red paint match...
  • Fossil
  • Fossil's Avatar Topic Author
09 Aug 2006 19:42
#68409
...found a little tin of fresh touch up paint from the body shop left over from years ago when my wife's car was hit and repaired. Turns out to be a perfect match to the original red on my bike. 1991 Pontiac Tempest red. Nope, sorry don't have the paint code on hand.
  • Pterosaur
  • Pterosaur's Avatar
Re: GPz1100 red paint match...
09 Aug 2006 20:15
#68423
A ten minute pit stop at any body shop or auto parts store that does paint mixing should be able to give you both the code *and* the formula - in grams - for your color in whatever manufacturer's (DuPont, PPG, Martin Seynor, etc...) system they're using.
Getting the formula is just as, if not more important than the base code when it comes to color matching; no two cans/batches of paint are ever created the same, short of perhaps the OEMs, who mix up 1000+ gallon batches under strictly controlled and automated conditions.
Short of those conditions, a *talented* Mk. I eyeball is hard to beat when it comes to comparing a test panel to a freshly mixed pint and figuring out whether it needs a gram of red or a half gram of blue to get it "right". Knowing the constituent colors in precise amounts can make or break a can of paint in a hurry.
For example, in a 1000 gram quart, some silvers may have as little as 5 grams of color, the balance being composed of binders and metallics...
Post edited by: Pterosaur, at: 2006/08/09 23:18
  • wireman
  • wireman's Avatar
09 Aug 2006 20:49
#68433
:evil:
Post edited by: wireman, at: 2006/08/09 23:49
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
10 Aug 2006 03:26
#68451
I, also, have a little can of left-over paint from a custom match for a 1982 GPz1100. It is Dupont Chroma 'Firecracker Red' for a 1991 Mercury Capri...and all the numbers (well, maybe most) are still on the can label.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • redrkt
  • redrkt's Avatar
22 Sep 2006 14:04
#78799
I'm about to get my '82 GPz750 repainted and have been told that the ColorRite Kawasaki 606 Firecracker Red 3015 is the right match for the GPz.
From what I understand, Kawasaki has been using this color for years, not just for the GPz, but for other vehicles, and ColorRite has simply matched it.
Is this correct? Thanks...
www.colorrite.com/product_info.php?products_id=355
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
22 Sep 2006 17:17
#78820
Don't know, but I sure would like to see some photos of the color.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
