  • Page:
  • 1
  • 2
replacement gauge faces 16 Sep 2016 20:58 #742578
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
  • Thank you received: 53
Have any of you replaced the faces on your speedometer or tach? Mine are getting pretty faded. I can't seem to find much info on replacing them. Maybe it's not something people usually do.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
replacement gauge faces 16 Sep 2016 21:54 #742580
  • Thank you received: 2098
replacement gauge faces 17 Sep 2016 00:37 #742588
  • davido
  • davido's Avatar
  • Thank you received: 286
One of mine was craked so I took the other to a glass shop and had a couple of new ones cut to the right size. Easy peasy.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
replacement gauge faces 17 Sep 2016 03:55 #742590
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1632
Is this for the 550 Zephyr? If so, the meters should be easy to open, but I have no idea if new faces are available.
replacement gauge faces 17 Sep 2016 06:36 #742593
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2651
I got two new ones on eBay. The toughest part is getting the needles off. I broke two spindles by prying up so now I twist them off.
kzrider.com/forum/5-chassis/599078-tach-speedo-rebuild
kzrider.com/forum/5-chassis/599906-new-tach-speedo
replacement gauge faces 17 Sep 2016 08:01 #742596
  • martin_csr
Some guys have had luck prying the needle with a couple of spoons.
replacement gauge faces 17 Sep 2016 08:13 #742598
  • SWest
  • SWest's Avatar
  • 10 22 2014
The top of the spindle is the thickness of a paperclip. That's the part that broke off on two of them. I had good luck before but those two were ruined beyond repair.
replacement gauge faces 17 Sep 2016 08:23 #742599
  • davido
  • davido's Avatar
Sorry,I misunderstood. I thought you were talking about the glass.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
replacement gauge faces 17 Sep 2016 08:29 #742600
  • Zaddict
martin_csr wrote: Is this for the 550 Zephyr? If so, the meters should be easy to open, but I have no idea if new faces are available.
Yes. Good to know it's pretty easy/common with other bikes. Need to find decals for my zr550, if they exist.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
replacement gauge faces 17 Sep 2016 08:56 #742603
Am guessing that other models might have the same or acceptably similar instrument face decals.
If not already done, would inquire of Diablo Cycle (owned and operated by the people at Reproduction Decals) and/or Reproduction Decals.
E-mail: This email address is being protected from spambots. You need JavaScript enabled to view it. or This email address is being protected from spambots. You need JavaScript enabled to view it. • Tel: 519 668-7152
Fax: 519 690-0774
www.diablocycle.com/home.php
www.reproductiondecals.com/default_frame...info_instr.html~main
Good Fortune! :)
Last edit: by Patton.
replacement gauge faces 17 Sep 2016 09:19 #742605
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought the actual face plates. You might try these folks to see if they have one for your bike. There are others as well.
replacement gauge faces 17 Sep 2016 16:21 #742653
  • Zaddict
Great tips - thanks all!
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • Page:
  • 1
  • 2
