  • Page:
  • 1
any way to seal vinyl decals on top of powdercoat? 24 Feb 2015 18:34 #662665
  • runmikeyrun
  • runmikeyrun's Avatar Topic Author
  • Thank you received: 3
I'm stripping my tank and having the steel powdercoated with clear. I created some large (13"x6") vector art for decals today for the tank, and I know that I can't apply them underneath the powdercoat since it gets baked on and the vinyl would melt.
I'm wondering if there's a way I can seal the decals after applying them on top of the powdercoat? If i spill a drop of gas on the decals they will be ruined, but I'm not sure if there's any clear coat paint I can apply over powder.
I opted to powder coat the tank vs. clear coat paint because research i've done shows more benefit from the powder with regards to durability and rust formation.
Oh and here's the decals I created. I'm going to trim to fit the contours of the tank since vinyl doesnt go around sharp corners lol. This is the left side, right side is mirrored except for the text.
Monkey? MONKEY? I'm a GORILLA you CLOWN!
Last edit: by runmikeyrun.
any way to seal vinyl decals on top of powdercoat? 24 Feb 2015 20:42 #662684
  • Racewayelko
  • Racewayelko's Avatar
  • Thank you received: 0
I am not a paint guy but why would you not be able to powder coat , place the decal, clear coat? is there something that prevents powder coating and clear coat from bonding to each other? I have seen people do that before with normal paint and put vinyl inbetween that and the clear. just my .02
Andrew
Keep it rubber side down everyone :)
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine :) )
any way to seal vinyl decals on top of powdercoat? 24 Feb 2015 22:09 #662698
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Spray it with Urethane clear coat. base coat / clear coat.
Car stuff! Euro clear. 2 part2K you know, 4:1 catalyst system. Good old poly isocyanate clear coat PPG, Dupont, trans star. You know, the stuff I have sprayed for 20 years, since I gave up Dupont 3708 Lacquer Clear
Yes you can clear it!
any way to seal vinyl decals on top of powdercoat? 24 Feb 2015 22:58 #662702
  • Racewayelko
z1kzonly wrote: Yes you can clear it!
Ha! High School Body shop wasn't a waste of time see mom!! :)
any way to seal vinyl decals on top of powdercoat? 25 Feb 2015 04:05 #662707
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Cool design.
78 KZ1000 A2A
The following user(s) said Thank You: runmikeyrun
any way to seal vinyl decals on top of powdercoat? 25 Feb 2015 11:35 #662745
  • runmikeyrun
Ok awesome, good to know. I hate to solely rely on the opinion of a painter.
any way to seal vinyl decals on top of powdercoat? 27 Feb 2015 07:13 #662869
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Just a tip on placing the graphics, big area like that can be difficult and I have screwed a few up in the past.
I do it different to the usual instructuions, I spray the surface with a mist of water with a drop of washing up liquid in, then place the graphic in place removing the backing paper complete. It sort of floats and it is easy to peel it back off when an air bubble gets trapped, or the grapihic is positioned wrong. The excess water can be squeezed out afterwards with a cloth. Also don't pull hard on the graphic as the vinyl discolours when stretched.
Clear coat over keyed powdercoat and graphics is the way to go. If your tank was less than perfect, and without the usual light skims of filler that most need, you might go for a satin clear. A glassy polished finish looks grat but will accentuate any bumps or ripples in the tank.
any way to seal vinyl decals on top of powdercoat? 27 Feb 2015 08:14 #662874
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Just wanted to add that if it is going on a tank make sure you use a solvent resistant clear coat like 2K or spilled gas will undo all of you hard work.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
any way to seal vinyl decals on top of powdercoat? 27 Feb 2015 16:59 #662927
  • runmikeyrun
Tyrell Corp, thanks for the heads up! I have some decal slide solution in the garage that I bought and never used, so I'll give that a shot. I know, ya gotta be gentle with the vinyl, it doesnt like being manipulated too much!
Kaw-A-Holic I think i'm gonna get it professionally sprayed. I'll just screw it up lol
any way to seal vinyl decals on top of powdercoat? 28 Feb 2015 05:49 #662960
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
If you put clear powder directly on the raw steel rust will form under the clear and crawl in a spiderweb pattern. It will last for a while though, just not sure how long.
Urethane on top of the powder/graphics will work. The bicycle guys do that and it works out well.
  • Page:
  • 1
