  • Page:
  • 1
  • 2
Black plastic color restoration? 08 Jun 2014 04:47 #635751
  • John T
  • John T's Avatar Topic Author
  • Thank you received: 2
1991 Zephyr rear fender
Whats the best way to restore the plastic back to black?
Looks like sun fading... I haven't tried anything on it yet like armor all or tire black etc...
I am considering spraying it with rattle can rustolium Plastic paint...
Any suggestions ?
Its not a full restoration , i just want it to look good.
True Wisdom Only Comes From Pain.
Black plastic color restoration? 08 Jun 2014 05:48 #635758
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
How about the stuff they advertise for automotive trim or
to clean up glazed over headlights? I have not had to deal with
the issue much on my pre "81 bikes much. The plastic air box
and inner rear fender I have cleaned up with carb cleaner etc....
It removed most of it but did not take it back to an 'as new'
appearance.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Black plastic color restoration? 08 Jun 2014 06:00 #635760
  • Thank you received: 2829
I use this spray, and it works great on my air box, etc. I spray it on a rag and apply it. Motorcycle shops and online sites sell it. Ed
Attachment Wax.jpg not found
Last edit: by 650ed.
Black plastic color restoration? 08 Jun 2014 07:23 #635766
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
I have used this on plastic. It works great. I used it on the rear plastic inner fender and plastic gauge cluster and have had no problems.
www.krylon.com/products/fusion-for-plastic/
I would try it on something else, other than bike part and see if you like it. It wont chip or peel.
Last edit: by 4TheKZ1000.
Black plastic color restoration? 08 Jun 2014 07:32 #635769
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2699
Back To Black will make it look half way decent. Agree with the guys suggesting spray paint though if you want it to look really clean.
Black plastic color restoration? 08 Jun 2014 09:51 #635774
  • John T
4TheKZ1000 wrote: I have used this on plastic. It works great. I used it on the rear plastic inner fender and plastic gauge cluster and have had no problems.
Yes.
I used that in the lowers on my SV650
It came out great.. Its been a few years now
Holding up
I found an old can of tire shine and gave it a go..
Came out nice..
Will see if it lasts...
Gave the old ZedRX a cleaning too...
Black plastic color restoration? 08 Jun 2014 11:49 #635780
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Z650Spirit over at the KZ650.Info site painted his airbox w Rustoleum Specialty Plastic Primer & Paint. He said the airbox was scratched up pretty bad, so he sanded it w 1000-grit. A much lower grit may leave scratches.
Last edit: by martin_csr.
Black plastic color restoration? 08 Jun 2014 11:55 #635782
  • 4TheKZ1000
  • Visitor
Only problem with the tire shine type of products is the finish attract dirt and fade with time.
When wet or not wet they also sling juice all over and on other parts.
The look is temporary.
Not familiar with the Firestone product.
I must say it looks great, good job.
Black plastic color restoration? 08 Jun 2014 12:13 #635785
  • mykznme
  • mykznme's Avatar
martin_csr wrote: Z650Spirit over at the KZ650.Info site painted his airbox w Rustoleum Specialty Plastic Primer & Paint. He said the airbox was scratched up pretty bad, so he sanded it w 1000-grit. A much lower grit may leave scratches.
You can go as low as 320grit with solid colors and 400g with metallics without leaving any visible scratches.
The reason I'm saying this is because plastics are a pain to paint and you need as much mechanical adhesion as you can get.
Plastics are synthetics so as they age they begin to loose the oils that keep them pliable and soft. It's these oils that keep the paint from staying put over time so the more "tooth" you have,the more the paint has something to hold on to.
Fusion paints aren't bad products and they will give you 5-10 years of life if taken care of.
If it were mine I would key it up with 320g and spray it with M.E.K. To loosen the surface tension and then shoot it with a 2part urethane or 2k automotive clear.
Cheers,
R.I.P. Odd Ivar
Black plastic color restoration? 08 Jun 2014 22:13 #635878
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Cheers,
You are absolutely right about the grit. I painted my airbox. i sanded with 120 to get as much tooth as possible. Then I wiped the whole thing down with acetone, and then Immediately sprayed Rustoleum plastic primer, 2 coats. Then sanded with 320, then Rusto semi gloss. looks great. but time will tell how it holds up.
Black plastic color restoration? 08 Jun 2014 22:19 #635880
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
  • Thank you received: 50
John T wrote: SV650
ZedRX
You have good taste in bikes, sir.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Black plastic color restoration? 09 Jun 2014 06:35 #635897
  • martin_csr
mykznme wrote: You can go as low as 320grit with solid colors and 400g with metallics without leaving any visible scratches.
Thanks. The airbox isn't mine and the grit stuff was his method. :)
1000 grit seemed rather fine to me, but it came out looking so good,
I wasn't about to contradict the way he did it. hee.
  • Page:
  • 1
  • 2
