rusty tank blah, n2 spectre
- purls
25 Feb 2011 19:32
Okay, my tank has some rust inside. I'm thinking of using kreem or red kote. Bad idea or no? Anything else I can do besides taking it to a shop, or is the radiator shop the only way to go?
thanks a ton
purls
thanks a ton
purls
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- MFolks
Re: rusty tank blah, n2 spectre
25 Feb 2011 20:30
Try this:
Oxalic Acid Rust Removal On Gas Tanks(Found On the internet at www.wgcarbs.com )
Just ordered a few pounds of it this morning, it "should" remove the rust in my Kaw tank and it's great for removing rust on shop tools or whatever too.
I used this stuff while I lived in Florida where the humidity usually averaged 100% and it saved me a lot of labor ... it's Eco friendly too. Our humidity here in Alabama is just about as bad as on the gulf coast ... so even if it won't completely clean the tank rust out ... and I truly believe it will ... I can make good use of it
Don't know why I didn't think about it sooner, mixes with tap water, flushes out easy, it won't harm paint, plastics, aluminum or anything of that nature ... just kills the rust and leaves the metal coated to help prevent future rusting.
The guy's name is Gregg and he has a ebay store but you can buy directly from him, send payment by check or paypal. I talked to him yesterday and told him there would probably be more folks from the forum inquiring about it. He said to have whoever calls or emails to remind him they're from the forum.
It sells for $4 a pound and he can fit 4 pounds into a flat rate priority mail package and ship it for $4.95. So 4 pounds should go along way since it can be used over and over again. $20.95 for 4 pounds shipped isn't bad at all in my opinion. The only way he's making any profit on it is by buying LARGE quantities and selling small.
I'm probably going to set up a large vat to soak tanks and tools in.
This stuff will eventually turn black after heavy use but it still cleans good and washes clean with tap water.
He claims he's had several people use it for cleaning rusty tanks with great results and I know I had good luck with it before too, just never used any on a tank ... but will soon.
Here's his info: Best to try his cell first.
Gregg MacEllven
Sea Shield Marine Products (sales rep)
Mac's Pacs; teak/mahog plugs, flax, oxalic, etc.
macspacs@sbcglobal.net
310-547-2687 (home)
310-547-2606 (fax)
310-721-9667 (cell)
Late yesterday afternoon I mixed up a batch and put it inside my original KZ tank.
The tank had what I would call a medium overall surface rust throughout the inside and a fairly heavy rust build up along the entire bottom surface.
The instructions suggest warm water but I talked with Gregg and he said it wouldn't really matter as long as I wasn't looking for INSTANT results and let it soak so I used unheated water from the hose and about 8 heaping tablespoons of Oxalic acid and let it soak for 24 hours.
I just drained the tank and the water was colored kind of a light brown, I flushed the tank with clean water twice and looked inside as far as I could see with a strong miniature LED flashlight and NO RUST was present ANYWHERE including the bottom surfaces.
The Oxalic acid left behind a off white colored protective coating on the metal surface just like Gregg said it would
Once I got the tank dry I saturated a shop rag with gas and rubbed the white coating with it and the coating stayed put.
But ... I will highly recommend you folks give this stuff a try because it sure takes the work out of removing rust from our gas tanks and it did not faze the paint either where I overfilled it.
This old tank will get repainted and used now that the rust is gone ... but for you folks that have internal surface rust on tanks that still have good paint on them, don't worry ... this is the ticket right here !
I can tell you right now that it works very well, the tanks I cleaned back in November have sat in my shop until I decided to tag & drive my 78 KZ a few days ago.
I looked at all 3 tanks & they still looked rust free inside other than a small haze which may be simply what the metal looks like after sitting so long after being treated. I thru a 1/2 gallon of gas in it, sloshed it around, poured it out, installed the tank with clear gas line & the fuel runs out CLEAN ... no rust deposit showing up in the filter either !
Oxalic acid WORKS better than anything I've ever tried in 30 years of wrenching. Use hot water, mix it up double or triple strength, fill the tank to the rim and let it sit overnight. If you don't get the results you want, do it again, this stuff is cheap and WILL clean the rust out of tanks without harming the paint even.
I kept several gallons of used mix in a large plastic container & constantly throw stuff in it like a set of rusted boat trailer wheels, impact sockets etc. & it cleans them like new, may take a while but it works.
Some tanks may require more acid to do the job but this stuff is cheap & easy to use, won't even burn the grass when poured out.
I did a Honda tank for a buddy that had some ridiculous rust along the inside bottom flat areas & top part of the hump. I tripled the recipe & let it sit a couple of days and it came out CLEAN.
Would rather NOT use a tank liner product that may or may not peel away ... oxolic axid won't hurt the paint either, so that's a huge plus.
Gregg MacEllven
310-547-2687 (home)
310-547-2606 (fax)
310-721-9667 (cell)
- purls
25 Feb 2011 20:41
That sure sounds like my solution. The rust I have is minimal, so this should work just fine. I'll have to give this guy a ring. Oh by the way, I was cramping up thinking about putting that liner in the tank; so relieved there is a better solution. Doesn't affect paint either? Hell I can clean it whenever I feel like it.
Two questions, though, how does this compare to muriatic acid, and where does the coating you spoke of come from?
thanks
purls
thanks
purls
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- MFolks
25 Feb 2011 20:54
Muratic acid will damage paint, the coating mentioned in the article is a result of the Oxalic acid reacting with metal.
- Topper
26 Feb 2011 06:32
I had some rust in my tank and used some off the shelf rust disolver from the local auto parts store to remove it.
It worked well, but created some pin hole leaks in my tank that let the gas seep through and ruined my paint.
I coated the inside of the tank with Red Kote and had it repainted. It's a great product, very easy to use and a whole lot cheaper than a radiator shop. I wouldn't hesitate to recommend Red Kote.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
Last edit: 11 Feb 2013 13:06 by martin_csr.
- purls
26 Feb 2011 08:09
thanks all, I think I can get away with just a rust remover, but I'm gonna wait until I'm ready to roll. The paint will be new by then, so hopefully I wont trash it in the process. Luckily, the painter is a friend of mine who really wants to see this bike on the road. What would I do without friends...
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- catseye
26 Feb 2011 09:03
I've been looking at this stuff for mine:
I've seen it demo'ed, and looks almost too good to be true, but am willing to give it a shot. Anyone ever used it?
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
1976 BMW R90/6
1982 Honda CBX
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
09 Mar 2011 22:44
MFolks wrote:
I'm picking up a couple pounds of the stuff this weekend I'll be in his area so if Mark or Chris or any body els over here wants me to get some let me know.Try this:
Gregg MacEllven
310-547-2687 (home)
310-547-2606 (fax)
310-721-9667 (cell)
- ed spangler
- Tennessee Z
27 Mar 2011 15:42
Hi Wagonmaster
How do you think this compares to using Muriatic acid , which i can get at Home Depot fairly cheap.?
Did you have to neutralize the tank with anything after cleaning with this product you used?
Could a person just pour some WD-40 in the tank after cleaning with the product you refer to?
For enough to do one tank, whats the cost?
I have an old tank that i want to use while i am painting original tank.
can you ( please ) give me some specific ideas / step by step for the process?
I have access to hot water does that allegedly work faster?
Last question, what do you estimate thetotal cost for enough to use triple strength on one tank?
Where would I obtain this product?
Thanks!!
ED
Thanks!!
ED
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- ed spangler
- Tennessee Z
27 Mar 2011 20:52
Hi MFFOLKS:)
Please let me knopw how this works , and if it does...please tell me a step-by step how you did it.
Do you plan on using a neutralizing agent after the cleaning? WD-40? Liner?
I have an old tank that i want to remove the rust from the inside of tank and spend very money on, maybe if you are pleased with it could you sell me enough to do my tank?.
Thanks Sir!!
ED
Thanks Sir!!
ED
