Yea, this has been discussed as long as kreem has been around, 30 yrs or more. You can't expect a 4oz bottle of acid mixed with 3 or 4 gallons of water to properly clean the tank. It just can't do it. So you use any sealer after properly etching the tank, you'll be fine. Get your own phospheric or muriatic acid and do it right-strong. I did a couple of my motorcycles 10 yrs ago with kreem and there is no problem. Mek will remove kreem, but it takes a long time. One more thing guys do wrong is try to apply the coating too thick. After you etch and dry the tank, add the kreem or other sealer, let it coat all the interior of the tank, then let the tank sit a few minutes, then repeat. This "repeat" is where problems will begin to rear their ugly head. Each "repeat" the sealer is beginning to get more thick. If you're not careful a 1/4" thick gooey messs will be in the tank unable to drain because it's hardened. So the best thing to do is coat the tank once, repeat maybe once more, then quickly drain it out of there before it's too late. Plenty of seal there with the added benefit, should it fail and peal, at least there's less of it to get rid of.
