Gun Kote 1200?
- switch
- 1981 KZ1000m CSR
Gun Kote 1200?
23 Dec 2008 11:08
KG industries, Stock Kote, 1200 Air Cure. Anyone else out there tried this product? I have had my difficulties and would like to share experiences with anyone else.
I have had some success, but with this _____ storm and the temps, my unheated garage has not been hospitable to painting. So, I thought I would do the next best thing and Talk about it.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
- switch
- 1981 KZ1000m CSR
Re: Gun Kote 1200?
02 Jan 2009 22:12
WELL, I CAN REPORT SUCCESS AT LAST! SEE MY THREAD AT "PROJECTS". THIS IS AN AWSOME PRODUCT. THERE IS A TRICK TO IT, AND IF ANYONE NEEDS TO KNOW, I AM GLAD TO SHARE MY EXPERIENCE WITH PREPARATION AND APPLICATION.
BELOW ARE MY TRIPLE TREES WHICH I PAINTED IN 35 DEGREE WEATHER IN MY UNHEATED GARAGE.
THE LOWER WAS CHROME PLATED ORIGINALLY.
1981 KZ1000 M1 CSR
- PLUMMEN
Re: Gun Kote 1200?
02 Jan 2009 22:30
how does it go on,is it baked?
- switch
- 1981 KZ1000m CSR
Re: Gun Kote 1200?
04 Jan 2009 21:16
Plummen,
This stuff was originated to coat parts that can't be BAKED at 325 F. I couldn't get my oven rigged for the 50 amp service, so I went for this material. BUT, for this coating you have to HEAT the part just as you would for the bake on stuff.
Luckily, you only have to get it up to 110- 120 F. Then the water in the coating will flash off and the coating will adhere. Then it sets up and cures at room temp. I shot mine at 34 degrees F and it cured out in a couple hours at that temp.
They do say that you can brush or even roll this stuff on! But I haven't tried that, as my spray has been sufficient.
It looks good. You can get as much coating thickness as you want. You can recoat after the initial covering has set up. Maybe the brush will come in handy for any rock dings that might occur, although this is supposed to be every bit as tough as the bake on.
Thank for asking.
Thank for asking.
1981 KZ1000 M1 CSR
- Tony
Re: Gun Kote 1200?
04 Jan 2009 21:25
Thanks for the info switch. It will come in handy.
When I gunkoted my engine parts the issue was the oven. I used the one in my kitchen and the house smelled a bit for a couple of hours after.
Since then Ive baked lots of cakes and they taste fine.
- PLUMMEN
Re: Gun Kote 1200?
05 Jan 2009 06:46
i baked the paint on some aluminum boat headers in an apartment years ago before i got married,my neighbors didnt lke me much!:blush: :laugh:
- switch
- 1981 KZ1000m CSR
Re: Gun Kote 1200?
08 Jan 2009 14:10
I am temporarily w/o a computer at home. will be a week before I am on line again. I am posting from work, so this will be brief.
Tony, I would check w/ KG Industries about how much heat the cured 1200 series paint will withstand. Theorectically it is for parts that can't be heated, so I am doubtful about engine parts. it's a good question though.
1981 KZ1000 M1 CSR
- switch
- 1981 KZ1000m CSR
Re: Gun Kote 1200?
10 Feb 2009 21:43
I have been absent for a lot of reasons, but I had a breakthrough tonight I thought would be of interest. I have painted the lowers on my forks, and stupidly not masked off the upper end. So I found myself with some great looking painted parts, with a fine coating of abrasive on the inside of the tube!
Sprayed it out with Brake cleaner. It worked great, but most of all, I had my first test of the quality of this paint product, and it did not even touch the finish. I am gaining respect for this stuff.
New computer tomorrow! Have lots of pics to post on Projects.
1981 KZ1000 M1 CSR
- Tony
Re: Gun Kote 1200?
11 Feb 2009 00:08
Hey switch, Good to see you back again. It's interesting you should post this today. I talked to kg coatings today about using the air cure gunkote on engine cases and they advised against it. So I guess that is that.
I have my 750 engine torn down. I've been using paint stripper to remove the old gasket material from the engine cases, so of course it's taken paint with it. I guess it will be baked on gunkote for the 750 engine cases.
Here's a link to my first gunkote project.
gunkote project
Looking forward to seeing your pics.
gunkote project
- otakar
Re: Gun Kote 1200?
11 Feb 2009 07:45 - 11 Feb 2009 07:48
I have been useing gunkote for about 30 years. I must say that it has its place. where you are useing it is not it. Gunkote is fantastic on certain but not all engine and carburetor parts. It is a very hard hence brittle finish. I use it on guns and it is fantastic because of the thin film. Where you used it you should have used one of two products. Either "Por-15", or "Polane" both of these finishes are almost as good as powder coat but you can do it at home. Take a look at my thread where I talk about gunkote.
kzrider.com/index.php?option=com_kunena&...=11&id=229829#229829
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Feb 2009 07:48 by otakar.
- otakar
Re: Gun Kote 1200?
11 Feb 2009 10:19 - 11 Feb 2009 10:21
Polane is available from the Commercial paint division of Sherwin-Williams. There are two different hardeners for the paint. One is "B" catalyst and one is "A" catalyst for outdoor use. you want "A" catalyst Part # V66 V 29. There is also Polane "B" and Polane "T" you want "B" which is gloss. The "A" hardener will take longer to cure but it will last almost forever. Polane was originally designed to be used without primer over metal. I plan on useing it on my engine cases, cylinder block, head and valve cover. The Gunkote I use on the side-covers and carburetor covers. The carburetor housings I will also use Polane.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 11 Feb 2009 10:21 by otakar.
- Tony
