  • Page:
  • 1
Modern Tire For 3.00 x 18 front? 07 Apr 2024 10:11 #897345
  • chopper1963
  • chopper1963's Avatar Topic Author
  • Thank you received: 8
What size is the 3.00 x 18 in the new tire math? I'm hoping to put a BT-46 Bridgestone on to replace the original tire from 1975. Would that equate to a 90/90-18M/C ?
Suggestions welcome.
Modern Tire For 3.00 x 18 front? 07 Apr 2024 11:25 #897346
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2685
90 would be good...
The following user(s) said Thank You: chopper1963
Modern Tire For 3.00 x 18 front? 07 Apr 2024 19:41 #897361
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 511
There are conversion charts published for converting inch to metric tire sizes.  For example: www.cyclegear.com/assets/0002/8205/Tire_Size_Convertion_PDF.pdf
Alternately, the Bridgestone site for the BT46 shows the "standard" rim width for each tire size, as well as the acceptable width range for each size.  I believe the standard rim width is what is used to measure the advertised tread width and overall diameter.
www.bridgestone.com/products/motorcycle_...oducts/detail/pr176/
The rim/wheel size should be stamped on the wheel.  Many KZ wheels were 2.15" width, but I don't know what you have.  Once you find the wheel width, you can look at the standard width and width range for each tire size and get a sense for what will fit.  I personally bumped the tire sizes up a bit beyond the "standard" width, but you may have issues with fender and chain guard clearance if you push it too far.
My dad's '74 Z1
'00 ZRX1100
  • Page:
  • 1
