  • Page:
  • 1
Key blanks data 25 Mar 2024 20:12 #896891
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
  • Thank you received: 620
Found this today. A data handbook for locksmiths.  Might be useful some time.  In .pdf format.  Click or right click the icon at the bottom to open or save.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: Mcdroid, rangeroy, Wookie58
Last edit: by slmjim+Z1BEBE.
Key blanks data 26 Mar 2024 16:21 #896932
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Thanks.
I saved it.
Probably already have the information in books and computer programs I have, but still good to have.
I can make the keys by the code number, if anyone is in need.
Rob
Two old key machines below: a Jensen Micro Dial Key Crafter, similar to a small lathe, and an early 1900s skeleton and regular key machine.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: slmjim+Z1BEBE, gd4now
Last edit: by rstnick.
Key blanks data 27 Mar 2024 11:53 #896968
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 374
Those are some interesting looking machines Rob. Are they units you use still?
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Key blanks data 29 Mar 2024 16:24 #897059
  • rstnick
  • rstnick's Avatar
Yes, Bruce.
The mini lathe one is a manual code cutting machine.
Comes in handy when the computorized machines can't do the task.
The older machine was one my father bought from someone else, sans motor to save weight. Little did he know the motor has/needs the proper gear to connect to the drive, and we haven't found one since. It's more a Museum piece.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
  • Page:
  • 1
