  • Page:
  • 1
rear hub damper 17 Dec 2023 18:14 #892844
  • db
  • db's Avatar Topic Author
  • Thank you received: 0
hi derek from australia  am rebuilding rear hub need  42014-026 damper every where i searched seems out of stock  any help much appreciated thanks derek
rear hub damper 18 Dec 2023 03:11 #892850
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 656
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
rear hub damper 18 Dec 2023 05:26 #892851
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 305
Good Ridin'
slmjim & Z1BEBE
I think that slmjim and Z1BEBE are referring to your elusive hub damper.  There are currently 5 on eBay.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
rear hub damper 18 Dec 2023 05:37 #892853
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
It looks like some of them listed as 42014-026 are different and possibly a newer style. I don't know how interchangeable they are.  If you can use the type found on the 1981 K650-CSR, it was used on a bunch of different motorcycles (42014-033).  Partzilla has a cross-reference.  Another possible option is to repair the old one if it seems doable. some guys used polyurethane adhesive, I think what's used on car windshields.
EB item number:  355161537077. I'm assuming this one is the 42014-026.
Last edit: by martin_csr.
rear hub damper 19 Dec 2023 06:28 #892887
  • slmjim+Z1BEBE
Good Ridin'
slmjim & Z1BEBE
Yup.  We pasted a fleabay link & didn't check it afterwards.  Kunena choked on it for some reason.  Apologies for the broken link.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
rear hub damper 19 Dec 2023 07:37 #892890
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 684
Old school but very effective fix is to cut up an old inner tube into strips and fold them over the sprocket carrier prongs to fill the wear of the damper rubber slots.
Z1000J2 somewhat modified!
  • Page:
  • 1
