Newer Sportbike Controls swap 08 Jan 2017 15:16 #751730
  • BOOM_FIST
  • BOOM_FIST's Avatar Topic Author
  • Thank you received: 5
Wondering if newer style sportbike clip on controls would work on a standard handle bar set-up? As in, slide the controls, throttle tube, levers, etc off of the clip ons and put them onto our handle bar set up. I'm pretty knowledgeable on rewiring all the switches, so that won't be an issue. The only issue I would see is that some of the newer throttle cable ends I've seen aren't the same as our set up, but I'm sure I can fab something up to make them work?
Anyone already accomplish this swap?
Any info would be awesome.
1977 KZ900A5
Newer Sportbike Controls swap 09 Jan 2017 15:55 #751815
  • BOOM_FIST
Well, just bought a used 07 ZX10 complete left clip on for pretty cheap to try it out.
I'll update to see if this works out the way I planned. If it does, I'll buy a right clip on and try and convert the throttle side.
1977 KZ900A5
Newer Sportbike Controls swap 09 Jan 2017 17:07 #751825
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
only concern is if the new control wires are not long enough to reach the original harness. if it does its just a matter of wiring it up correctly
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Newer Sportbike Controls swap 09 Jan 2017 23:10 #751838
  • davido
  • davido's Avatar
  • Thank you received: 286
I fitted ZX9R controls to my CSR1000 build.From clip-ons to quite wide,straight bars. Length was a bit of an issue but I just about managed it.
I also had to modify the throttle cable. The biggest challenge was wiring up European ZXR switches (with a headlight on/off and a pass button) to an American loom. Im not an electrician.
The other thing Im not sure about yet is if the angle of the master cylinders is going to be a problem, I havent bled the brakes/clutch yet. Thats another thing. To satisfy my sense of symmetry, I had to ditch the cable clutch and convert to hydraulic. Its all in my build thread somewhere.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Newer Sportbike Controls swap 10 Jan 2017 00:49 #751842
  • BOOM_FIST
spdygon wrote: only concern is if the new control wires are not long enough to reach the original harness. if it does its just a matter of wiring it up correctly
I'm pretty good with wiring and such, so it shouldn't be an issue either way.
davido wrote: I fitted ZX9R controls to my CSR1000 build.From clip-ons to quite wide,straight bars. Length was a bit of an issue but I just about managed it.
That's good to know...this should be a pretty straight forward swap then.
I'll report back with my progress....
1977 KZ900A5
Newer Sportbike Controls swap 10 Jan 2017 09:22 #751864
  • 80B4
  • 80B4's Avatar
  • Thank you received: 105
The master cylinder will be the hard part. Do you have duel or single front calipers? I use these modern switches.
The left side switch has a passing light switch and it will also turn the headlight off.
1980B4 1000
1978 Z1R
1978 B3 750
Newer Sportbike Controls swap 10 Jan 2017 10:33 #751871
  • StreetfighterKz
  • StreetfighterKz's Avatar
I use the exact same items that 80B4 posted. I use an aftermarket Motion Pro dual cable throttle housing instead of the stock one. Been running that way for almost 15 years now.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Last edit: by StreetfighterKz.
Newer Sportbike Controls swap 15 Jan 2017 08:25 #752239
  • BOOM_FIST
So I ordered the left clip on off of a 06-07 ZX10R and it came in last week. It fits great. Still haven't looked into the wiring, but again that's no big deal. I went ahead and ordered a full right clip on from the same year 06-07 ZX10R and some new MZS shorty adjustable levers. The master cylinder swap shouldn't be too hard once I figure out the length I need for the brake line. Once I get all the parts in and some more time in the garage, I'll snap some pics with it all mocked up. It should look pretty sweet.
Now I'm looking for a more sleek all-in-one digital cluster set up to continue the modernization process along with a HID or LED Headlight and LED Taillight set-up.
1977 KZ900A5
Last edit: by BOOM_FIST.
Newer Sportbike Controls swap 23 Jan 2017 08:18 #752738
  • BOOM_FIST
Got all the parts in and temp installed everything onto the handlebars, but with the original KZ controls just to see how they look and fit. The original RH KZ control is too wide and won't allow the ZX brake lever assembly to be adjusted to a suitable pitch. It's hitting the triple tree right where the fork mounts. The LH control fits perfectly fine.
Going with the original plan to swap over the ZX controls, but looking to find the correct connectors to make it plug and play without hacking up the original bike harness or hacking off the new reman original control harnesses.
Can anyone confirm the connector type? If I remember right what the connector looked like....some research shows it might be a 110 series 6 pin female like this one: www.houseofkawasaki.com/namz-custom-cycl...m?productId=22511886
I'm at work now and can't get my hands on the connector until later, but it would be nice to have someone else confirm this.
1977 KZ900A5
Newer Sportbike Controls swap 24 Jan 2017 20:14 #752856
  • jowek70
  • jowek70's Avatar
  • Thank you received: 26
BOOM_FIST wrote: Got all the parts in and temp installed everything onto the handlebars, but with the original KZ controls just to see how they look and fit. The original RH KZ control is too wide and won't allow the ZX brake lever assembly to be adjusted to a suitable pitch. It's hitting the triple tree right where the fork mounts. The LH control fits perfectly fine.
Cycle terminal.com
Wiring might be more complex than you're thinking
Newer Sportbike Controls swap 25 Jan 2017 05:22 #752861
  • BOOM_FIST
I've already looked at that site and it doesn't look like they have the connector I need.
I already have the wiring pretty much sorted out. I made this simple diagram in paint. It's really not that hard.
1977 KZ900A5
Newer Sportbike Controls swap 25 Jan 2017 05:27 #752862
  • BOOM_FIST
1977 KZ900A5
