  • Page:
  • 1
  • 2
Hand Grips 09 Oct 2016 17:44 #744879
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Ive used spray paint on my mx bikes for years. Mid pack B rider so they got some abuse.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Hand Grips 11 Oct 2016 20:34 #745009
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2073
I have used chlorinated brake cleaner.
Patton wrote: Before resorting to glue, would try cleaning both the bar and inside grip with household rubbing alcohol, and then using the alcohol as a medium to slide the grip onto the handlebar (or throttle tube). Allow to dry before using.
Probably depends somewhat on the particular grip being fitted. But I just clean the bar and grip, then use air pressure with cone nozzle to quickly fit the grip on to handlebar and throttle tube. Grips stays firmly in position, and zero slippage.
Another possibility, as opposed to glue, is hairspray applied to clean bar and grip interior, and slide grip into position before the hairspray dries. Then allow to dry before using.
I have never resorted to using glue. What a mess. And difficult to remove.
My brand new Z1's and KZ900 came from the factory without any glue to hold on the grips, and the stock grips without any glue held on just fine, and never posed an issue.
YMMV with whatever aftermarket grips are being fitted.
Good Fortune! :)
Hand Grips 12 Oct 2016 00:46 #745018
  • Barry2
  • Barry2's Avatar
  • Thank you received: 23
There is just no other thrill like the adrenaline boost you get when the left hand grip pulls off under hard acceleration.
Use the grip glue.
1976 KZ900
The following user(s) said Thank You: 650ed, SWest
Last edit: by Barry2. Reason: spelling
Hand Grips 13 Oct 2016 04:01 #745100
  • grumpy56
  • grumpy56's Avatar Topic Author
  • Thank you received: 6
YIKES :ohmy: :ohmy: :ohmy: :ohmy:
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Hand Grips 13 Oct 2016 05:34 #745106
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Barry2 wrote: There is just no other thrill like the adrenaline boost you get when the left hand grip pulls off under hard acceleration.
Use the grip glue.
Not quite as dramatic, but I was pushing my bike around in the grass the other day & I can imagine an unglued grip coming off while maneuvering the bike backwards.
  • Page:
  • 1
  • 2
