Z1 Front Rotor Lockwashers - Distorting
  • BritGuyUSA
  • BritGuyUSA's Avatar Topic Author
03 Nov 2015 19:14 - 03 Nov 2015 19:22
#697116
OK. So I've just rebuilt my front hub, - new bearings/seals etc. Laced into a new rim, mounted a new tire etc.
Everything's going great until I go to fit one of the two new rotors. 6 brand new bolts, 3 brand new two-bolt locking 'tab' washers. Threads were chased. I'm using Loctite blue on the bolts.
FSM gives a torque range of 25-33 ft/lbs. I set my click-style torque wrench at 15 lbs for a first pass. All is fine. I bump it up to 22 for a second pass, and notice that the lockwashers are distorting under the bolt heads - buckling and twisting. By the time I get to 30 for my final clamp down, the lockwashers are almost torn in two.
There are no regular washers under these bolt heads obviously as this would make the tabs on the lockwashers useless, so it's obviously the underside of the bolt heads that are biting into the lockwasher and causing this distortion. (The Factory Parts Manual shows nothing but the bolts and the lockwashers either.)
Has anyone else had this problem, or am I just doing something really dumb here?
'75 Z1-B, '78 CB750K8, .79 CBX1000, '85 VF1000R, '94 XR650L, '95 Triumph Speed Triple
Last edit: 03 Nov 2015 19:22 by BritGuyUSA. Reason: Clarity
  • DoctoRot
  • DoctoRot's Avatar
Re: Z1 Front Rotor Lockwashers - Distorting
03 Nov 2015 19:31
#697117
I haven't heard about this happening, but there is no real need to use lock washers if you are using lock tight; unless you are going for a resto of course. Are you using the stock flange bolts? perhaps put the tiniest film of grease under the flange to prevent the bolt from biting in the soft lock washer.
  • BritGuyUSA
03 Nov 2015 19:36
#697118
Here's a pic of the problem:
Attachment LockwashersA.jpg not found
Any ideas?
  • BritGuyUSA
03 Nov 2015 19:42 - 03 Nov 2015 20:16
#697122
DoctoRot wrote: I haven't heard about this happening, but there is no real need to use lock washers if you are using lock tight; unless you are going for a resto of course. Are you using the stock flange bolts? perhaps put the tiniest film of grease under the flange to prevent the bolt from biting in the soft lock washer.
Yep the bolts are stock - brand spanking new from Z1 Parts as part of their dual disc conversion kit.
I might just scrap the lockwashers, clean up the bolts, add flat and spring washers and hit them with some red Loctite.
It's along the lines of a restoration, but I'm not looking to build a trailer queen by any means. There are a number of parts that were chromed by one of the POs that I'm not going to change back to standard, so I'm not looking for any more than 95% originality.
Last edit: 03 Nov 2015 20:16 by BritGuyUSA. Reason: Clarity
  • barney
  • barney's Avatar
04 Nov 2015 04:58
#697154
Looks like the locking tabs are too soft of a material
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Nov 2015 06:12 - 04 Nov 2015 06:16
#697172
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • z1kzonly
  • z1kzonly's Avatar
04 Nov 2015 07:11
#697181
Plus 2 on the quality! unfortunatlly just crap chinese knock offs.
Not worried about Original, just lock washer and blue loc-tite
Want original, find an OEM set and re-zinc plate them.
  • BritGuyUSA
04 Nov 2015 07:52
#697188
Thanks folks.
They're definitely sub-par on the quality - a lot softer material than other tab washers I've come across. Unfortunately the originals were not on the front rotor when I disassembled. I got these as part of the dual-disc conversion kit as mentioned previously. (As a 'heads-up' they were in a bag labeled 'Koyama'.)
Attachment JunkLockwashers.jpg not found
I'm dumping these and going with Loctite and regular washers. I may look for some originals down the road, but the prices people are asking for these in OEM baggies are ridiculous.
  • Kapahulu
  • Kapahulu's Avatar
04 Nov 2015 08:24
#697195
Thanks for posting the pic. We'll avoid Koyama locking tabs.
2strokeworld.com
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Nov 2015 08:44
#697197
whoever you bought that "kit" from should find another supplier if you can't even use the things as they were intended.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • BritGuyUSA
04 Nov 2015 08:57
#697198
Kidkawie wrote: whoever you bought that "kit" from should find another supplier if you can't even use the things as they were intended.
Agreed. Next time I call Z1 Parts I am going to let them know about this problem.
  • jackleberry
  • jackleberry's Avatar
04 Nov 2015 09:12
#697199
You might also consider that you may be over torquing the bolts. Locktite acts as a lubricant and if the torque spec given was intended for dry bolts (usually for brake parts, it is), then you may be over torquing by a significant amount.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
