  • Page:
  • 1
  • 2
Need biggest tire for. Ltd550 29 Aug 2015 22:23 #687781
  • Sharkman
  • Sharkman's Avatar Topic Author
  • Thank you received: 0
So if I get new tires they have to be the biggest that can fit the bike. As long as it don't rub I'm fine. Please don't tell me to stick with skinny stock size. I need the chunky look. This will be a around the corner and back bike so no long trips anywhere. This is the look I'm going for
Need biggest tire for. Ltd550 30 Aug 2015 05:24 #687787
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
A fatter rear tire is probably going to be a tight fit. My 650-CSR has the same stock tire & wheel as the 550-Ltd, and there isn't much room to go much wider. A 140/90-16 might work, but it will be tight at the least. 130 mm = 5.1"
Look at the rear wheel to see how much gap there is between the swing arm & tire. Check & measure both sides --- one side may have less clearance than the other. Subtract an acceptable amount of clearance from the smaller measurement, multiply that number by 2, convert to mm if using inches, then add that to 130. I guess that's how I'd do it, anyway.
Last edit: by martin_csr.
Need biggest tire for. Ltd550 30 Aug 2015 07:04 #687795
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2074
Also be aware that each 140 tire will measure a little differently. Some of the manufacturer's websites offer actual width measurements.
Need biggest tire for. Ltd550 30 Aug 2015 07:19 #687796
  • Thank you received: 2829
TexasKZ wrote: Also be aware that each 140 tire will measure a little differently. Some of the manufacturer's websites offer actual width measurements.
Exactly! The image below shows 2 Michelin front tires. The designated size (100/90-19) is the same for both, but as you can see the actual size is very different. You should measure before buying. One other thing to keep in mind is that the cross-section of the tread will deform if a wide tire is pinched onto a narrow rim. Been there / done that. This may not matter much though since you won't be able to mount a really wide tire due to interference with the chain and swing arm. Ed
Attachment MichelinTireComparison2-3.jpg not found
Need biggest tire for. Ltd550 30 Aug 2015 07:23 #687797
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2681
How wide is the rear rim? For a 2.5" wide rim a 130 is the max recommended size. If the rim is 2.75 or 3.0 then you can go up to a 140, although I'm not sure about on-bike clearance. Just don't be dumb and ignore the rim size situation. Using a tire that's wider than the rim can support is not advised.
Need biggest tire for. Ltd550 30 Aug 2015 07:42 #687805
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
I have a 130/90-18 on mine. Next time I'll go to a 120. Waste of money.
Need biggest tire for. Ltd550 30 Aug 2015 08:48 #687814
  • martin_csr
The 550-Ltd Rr wheel is 3.0 x 16. Stock tire is 130/90-16.
Need biggest tire for. Ltd550 30 Aug 2015 09:33 #687825
  • Sharkman
If I have go with a tire that looks the part that fine with me. If I had the tools and money I would do the fat tire mod... But I'm not really trying to go that deep....
Need biggest tire for. Ltd550 30 Aug 2015 09:33 #687827
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
If you a are really set on a fatter rear tyre then get the right sized bigger rear rim for it, otherwise you will lose that precise steering feel.
You might have a few wider rear wheel options in the same cast alloy 7 spoke design from the bigger bikes of the same age,
Need biggest tire for. Ltd550 30 Aug 2015 10:48 #687843
  • 80B4
  • 80B4's Avatar
  • Thank you received: 105
Nothing screams "I'm a Squid" like wide tires on narrow rims. Just saying.
1980B4 1000
1978 Z1R
1978 B3 750
Need biggest tire for. Ltd550 30 Aug 2015 10:55 #687844
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
80B4 wrote: Nothing screams "I'm a Squid" like wide tires on narrow rims. Just saying.
HA ha ha.... got that right.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Need biggest tire for. Ltd550 30 Aug 2015 11:33 #687857
  • SWest
  • SWest's Avatar
  • 10 22 2014
Might as well be wearing shorts, tank top and flip flops. :lol:
Bikes like that don't go through mud puddles or any water for that matter. :dry:
  • Page:
  • 1
  • 2
