kz750 custom swingarm fab
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Vendor
22 Oct 2014 07:20 - 22 Oct 2014 07:21
#651396
it seems the site has been lacking on custom fab lately :whistle: ,
here's my contribution :P ,
cut some 3/8 thick stock and milled out the axle slots,
then used some 1/4 thick stock and boxed em in.
tigged em all up.
sanded off the welds on the outside and left the welds inside.
and.milled the angles on em.
layed out on the table.
Last edit: 22 Oct 2014 07:21 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: kz750 custom swingarm fab
22 Oct 2014 07:34
#651397
i fixture the axle plates and pivot tube to the table and start fitting the tube.
going with stacked one inch .065 wall chromo,seem welded and notched.
  • 531blackbanshee
  • Vendor
  • Vendor
22 Oct 2014 07:44
#651398
this arm is getting a an under brace as well.
again in 1"x.065 chromo.
fitted a piece of chromo aerotube for a cross member.
the cross member is also where the lower shock brackets will attach.
  • bluezbike
  • bluezbike's Avatar
22 Oct 2014 07:47
#651399
Super cool fab work Leon......that was a shot in the arm :woohoo:
79 KZ 1000 LTD
  • 531blackbanshee
  • Vendor
  • Vendor
22 Oct 2014 07:51 - 22 Oct 2014 07:53
#651401
and a lil dress up shot with the wheels and front end hung on the chassis.
one with the kz 650 tank.
right side
running dual air shocks front and center direct mount between the frame and arm.
here's the upper shock bracket mounting tube.
Last edit: 22 Oct 2014 07:53 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
22 Oct 2014 07:58
#651403
had to clean up the frame where we cut the sub frame off also.
i got the lower shock brakcets welded in last night but forgot pics :blush: ,
ill get some this eve and post tomorrow.
thanks for the kind words bluezbike.
  • fitscott
  • fitscott's Avatar
22 Oct 2014 10:34
#651415
That's gonna be one cool twin!
  • pete greek1
  • pete greek1's Avatar
22 Oct 2014 12:35
#651423
AWESOME , !!! :ohmy: :ohmy:
  • Tyrell Corp
  • Tyrell Corp's Avatar
22 Oct 2014 14:43
#651430
Very nice work, great to see your vision on a less commonly modified zed. :) impressive !
I like that double tubing, like the original lawson racebike and copied on the later zrx's.
The following user(s) said Thank You: pete greek1
  • 531blackbanshee
  • Vendor
  • Vendor
23 Oct 2014 05:50
#651515
thanks for the kind words.
i'm doing this work for someone so the choice of bike was his.
it is cool to get to work on something that is out of the "normal"box tho.
he wanted the dual upper tubes and direct mount air shocks,i was wanting a single upper tube and conventional style shock mounting.but that's whats cool about doing stuff for other folks it gets you to do things you may not have chose to do on your own.
the shocks all bolted into the lower brackets.
now to get the compressor mounted,sub frame fabbed etc. :evil:
  • 531blackbanshee
  • Vendor
  • Vendor
23 Oct 2014 05:58
#651516
The following user(s) said Thank You: 80B4
  • 80B4
  • 80B4's Avatar
23 Oct 2014 06:01
#651517
Nice work, I'm glad to see another KZ750b being built. I have a 78 that will be my next project, so I will keep an eye on this!
1980B4 1000
1978 Z1R
1978 B3 750
