  • Page:
  • 1
  • 2
Counter sprockets on a 1980 kz750H1 23 Aug 2014 12:46 #644907
  • skooterbum4real
  • skooterbum4real's Avatar Topic Author
  • Thank you received: 6
I've got the 530 pitch sprockets on this bike. I've gone from a 16t counter to a 17t. Is there room to put on an 18t counter, without having to remove the little splatter shield that bolts on around it??
I do almost all highway riding, so I'm trying to cut down on the high RPM's at cruising speed, as much as possible....
I have the smallest rear sprocket that Z1 said is available for this bike, so my only choice is to go bigger on the counter.
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
Counter sprockets on a 1980 kz750H1 23 Aug 2014 23:50 #644964
  • steell
  • steell's Avatar
  • Thank you received: 207
I doubt that's your only choice.
It's probably a bad idea to remove that shield.
You can get custom rear sprockets from Sprocket Specialist, they made the 37 tooth rear for mine.
The following user(s) said Thank You: skooterbum4real
Re:Counter sprockets on a 1980 kz750H1 24 Aug 2014 05:25 #644970
  • undiablo
  • undiablo's Avatar
  • Thank you received: 64
I have the same bike with 530 chain. 17t is the biggest counter you can fit.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Counter sprockets on a 1980 kz750H1 25 Aug 2014 01:28 #645045
  • skooterbum4real
Yea I wasn't liking the idea of removing the little metal shield. I've done a little bit of searching for a smaller counter sprocket, and haven't found one yet.
Did the 37t rear sprocket make a good reduction of your cruising RPM's ?? What size counter sprocket are you running ??
1976 KZ750 Twin
Counter sprockets on a 1980 kz750H1 25 Aug 2014 06:36 #645058
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
my mistake.
Last edit: by martin_csr.
Counter sprockets on a 1980 kz750H1 25 Aug 2014 10:35 #645085
  • steell
  • steell's Avatar
Sprocket Specialists
Rebel Gears
Sprockets Unlimited
PMP Sprockets
You need a smaller countershaft sprocket only if you want to go slower but have increased acceleration. So I'm assuming it's a smaller rear sprocket you're seeking, and the links above are your answer.
My experiences don't apply, as my 37 tooth rear sprocket came with the NOS Dealer Option KZ750 twin Morris Mag Wheel kit that I bought on eBay (second one I've had), and it changed rear wheel diameter from a 18" to a 16", so there's no way to compare it. On my previous bike with the Morris Mags I had to go to Sprocket Specialists to get a sprocket as there are no stock sprockets that fit the Morris mag.
I assume you have a 38 tooth rear, as that's the smallest commonly available over the counter for your bike.
Last edit: by steell.
Counter sprockets on a 1980 kz750H1 25 Aug 2014 10:46 #645087
  • skooterbum4real
It's got a 38t rear on it now.
I called Z1, and asked them to set me up with the tallest set of 530 pitch sprockets available for my bike. Or the maximum gearing that fits my bike, that will lower the cruising RPM's as much as possible. I found out they sold me sprockets that matched the stock gearing that the bike came out with. I was pretty disappointed with them doing that, especially when I later discovered they sell taller sprockets than what they sold me.
They sold me a 16t counter, and a 38t rear, leading me to believe these were the tallest I could go. Then I saw they had a 17t counter available for my bike. So I had to buy a second counter sprocket, which gave me about 4 more MPH at cruising speed, or lowered my RPM's by about 400 RPM.
I am looking for a 37t 530 pitch rear sprocket. I don't know if a 36t would be to much, making it difficult to take off from a dead stop ??
IMO the bike is running to high of RPM's running at 70 / 75 MPH.
1976 KZ750 Twin
Counter sprockets on a 1980 kz750H1 25 Aug 2014 10:49 #645089
  • skooterbum4real
Hey steell, would you be willing to let me know what they charged you for the 37t rear sprocket ??
1976 KZ750 Twin
Counter sprockets on a 1980 kz750H1 25 Aug 2014 10:52 #645091
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
These will be useful:
Chain and Sprocket Calculation
www.rbracing-rsr.com/chainlength.html
www.gearingcommander.com
Counter sprockets on a 1980 kz750H1 27 Aug 2014 14:38 #645395
  • skooterbum4real
Thanks for the links !!
1976 KZ750 Twin
Counter sprockets on a 1980 kz750H1 28 Aug 2014 07:49 #645469
  • steell
  • steell's Avatar
skooterbum4real wrote: Hey steell, would you be willing to let me know what they charged you for the 37t rear sprocket ??
It was about five years ago, and the cost was around $70
It's probably more like $90 by now. Give them a call.
Someone here was running 17/32 on a 750 twin. IIRC he said he was lightweight and he had no problem pulling away from a stop. Bountyhunter might remember.
Counter sprockets on a 1980 kz750H1 28 Aug 2014 11:09 #645498
  • skooterbum4real
Thanks steel !!
WOW that's a BIG change in the gearing !! I think I'm probably to heavy to be able to pull that gear setup off !! I bet I could get along with a 36t rear, but hate to take the chance on spending more money on something that doesn't work for me..... I've got a motorcycle recycle warehouse fairly close by. I think I'm going to get the measurements off the mounting holes on the rear sprocket, and go see if they have any smaller sprockets that will bolt right up, before I have something one off made.
1976 KZ750 Twin
  • Page:
  • 1
  • 2
