  • Page:
  • 1
Tire leaking 23 Aug 2014 05:22 #644859
  • koloj
  • koloj's Avatar Topic Author
  • Thank you received: 5
Well I'm just about to finish my restore and now find tire leaking when I spay soap water coming for the side between the rim and tire question are these tubeless tires 1980 KZ750 I haven't got to take tire off yet but will soon cause gonna change the bearings its also slow leak takes two days for it to deflate
Tire leaking 23 Aug 2014 05:42 #644861
  • Thank you received: 2829
Please add your bike's year and specific model to your signature line. Kawasaki made 3 different KZ750 models in 1980. According to Kawasaki.com if yours is a 2-cylinder KZ750-G1 it needs tubes. If it is a 4-cylinder KZ750-E1 or KZ750-H1 (LTD) it would have come with tubeless type wheels. Of course there is the possibility that some previous owner installed different wheels. Ed
Re:Tire leaking 23 Aug 2014 07:03 #644868
  • koloj
Its h1
Tire leaking 23 Aug 2014 13:01 #644910
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
Bottom line: if it's tubeless tire then you have a rim leak. You can fix that by installing a tube. If it is a tube type tire and it's leaking..... you can fix that by installing a tube.
Tire leaking 23 Aug 2014 15:59 #644923
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Two days to deflate isn't that slow, refit tyre and/or inner tube is the answer.
Tire leaking 23 Aug 2014 16:57 #644930
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 236
Could be as simple as corrosion on the wheel. Most guys change tires use soap/water, this causes rapid and constant corrosion and leaks can happen. Some guys swear by soap for a lubricant, but they are either lucky or just plain talented as tire changers using wrong lube. Get dedicated tire lube and insist on it when getting tires changed if you don't do it yourself. Back to the problem at hand, usually this condition can be fixed by removing the tire and carefully cleaning the bead seat area, then remove the corrosion on the wheel with a sponge/solvent then some fine sandpaper. Then reinstall the tire using the right lube and it will seal every time. Well exception is if the old tire is defective, which is rare. I'd bet on the soap/water/corrosion and cleaning will fix it.
Tire leaking 23 Aug 2014 17:22 #644934
  • JR
  • JR's Avatar
  • Thank you received: 429
My tires are tubeless.
I had a leak in front tire a couple of years back. Suspected a rim leak since I couldn't see anything obvious. Took the wheel off and brought it to my local motorcycle shop. When I picked it up later the guy said it was a rim leak (fixed) and dirt was the cause. Could have meant corrosion like Ron described. A cheap fix. No problems since
Tire leaking 24 Aug 2014 00:43 #644967
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
  • Thank you received: 61
Yes, your tires are tubeless... but what about your rims? If the rims DO NOT say "tubeless" anywhere on them, run a tube.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Tire leaking 24 Aug 2014 05:59 #644971
  • JR
  • JR's Avatar
!Seymore wrote: Yes, your tires are tubeless... but what about your rims? If the rims DO NOT say "tubeless" anywhere on them, run a tube.
1980 kz750/ 4 came with tubeless rims/ tires
  • Page:
  • 1
