  • Page:
  • 1
KZ900 for damper rods - help me remember 29 Jul 2014 21:35 #641948
  • Kapahulu
  • Kapahulu's Avatar Topic Author
  • Thank you received: 44
I stored these KZ900 fork damper rods a couple of years ago and just took them out the other day. I sent them off to Pro-Valve to get worked on. I'm actually planning to put them in my H2. I had read a service bulletin that said some H2 rods were replaced with KZ900 rods.
Anyways, can someone here familiar with KZ900 damper rods tell me if this looks right? Specifically, the spring and spacer? Nick at Pro Valve said it looks like they don't belong there. I don't remember - and looking at the parts fiche doesn't help me either.
2strokeworld.com
KZ900 for damper rods - help me remember 30 Jul 2014 05:03 #641958
  • Thank you received: 2829
I don't understand why they were sent to be "worked on." What work is there to do? It sounds like Nick is unfamiliar with KZ900 damper rods; I would ask him to just send them back before he"works" on them. :whistle:
Here's the diagram. Ed
Attachment 00005_2014-07-30.jpg not found
KZ900 for damper rods - help me remember 30 Jul 2014 09:33 #642001
  • MTH76
  • MTH76's Avatar
  • Thank you received: 6
You are looking at a lowering spacer, it keeps the fork tube from returning to the stock length.
They are also called lowering blocks used to lower the front of the bike.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
KZ900 for damper rods - help me remember 30 Jul 2014 14:35 #642038
MTH76 wrote: You are looking at a lowering spacer, it keeps the fork tube from returning to the stock length.
It does look like someone changed things. When I compare the photo to the Kawasaki.com diagram it looks like some bits and pieces are missing. Ed
KZ900 for damper rods - help me remember 30 Jul 2014 15:05 #642042
  • Kapahulu
To read about Pro Valve's work click here and go near the bottom of the page in the "chassis" section: www.klemmvintage.com/kaw500h1.htm
What they do is alter the valving, kind of like putting cartridge emulators but at a lower cost. They can work on any damper that's made of steel.
2strokeworld.com
KZ900 for damper rods - help me remember 30 Jul 2014 15:09 #642043
In that case they will very likely be altering or switching stuff, so I would think they would have what ever pieces are needed. Ed
KZ900 for damper rods - help me remember 01 Aug 2014 10:48 #642322
  • Kapahulu
Are there no KZ900 owners here who remember taking their forks apart?
2strokeworld.com
KZ900 for damper rods - help me remember 01 Aug 2014 11:37 #642329
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 303
I have some old-style damper rods...but at home. I'll take a peek at them when I get home and post later today.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
KZ900 for damper rods - help me remember 01 Aug 2014 15:20 #642360
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Looked at the damper rods I have (they came with a set of forks that were either KZ1000A1 or KZ900A4...can't remember) but they are identical to what you have pictured...in all parts. Not sure how this helps you but there you go.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
KZ900 for damper rods - help me remember 01 Aug 2014 15:51 #642367
  • Kapahulu
Mcdroid that does help some. I'll just reassemble "as is" and run 'em. I have a limited understanding of forks and just try to put things back the way I found them!
2strokeworld.com
  • Page:
  • 1
