- Thank you received: 1
530 to 520 Sprocket Advice
- pbmax
Stock is 530 16t/38t, but I would like to convert to 520 17t/34t.
I'm 99% sure the following sprockets will fit:
www.jtsprockets.com/catalogue/sprocket/JTF565-17
www.jtsprockets.com/catalogue/sprocket/JTR1478-34
I know the teeth on the 520 sprocket are thinner, but is the whole sprocket thinner or just at the teeth? Will I have to add any spacers or something like that?
Thanks!
- Thank you received: 2829
www.dansmc.com/ek_chain_specs.jpg
- pbmax
I know the teeth have to be narrower to fit the 520 chain, but what about the rest (center part) of the sprocket? Same thickness as a 530 one? I'm just wondering if I need to add spacers to keep everything lined up as it was in the stock configuration .
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
Your gearing choices are going to gear your bike way higher than stock. It will be very noticeable pulling away from a stop.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- 0Z.Z1R Mk2
- Thank you received: 31
Although it covers Z1000A1 - A4, Z1000D1 (Z1R), Z1R MkII, Z1000MkII, Z1000H only.
I have done this 520 conversion to my Z1R.
ksrc-au.com/phpBB3/viewtopic.php?f=31&t=...08&hilit=520#p608008
- Thank you received: 797
pbmax wrote: Let me rephrase...
usually the sprocket is the same thickness from spline to tooth.
but,
not always.
sometimes the splines are wider than the rest of the sprocket and teeth.
it will be obvious if you see a pic of the sprocket.
if you do not have sufficient sprocket thickness at the splines it can be made up with a custom spacer or washers stacked up.
hth,
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
a 102 link 530 non-oring EK brand chain is approximately 63.75 inches long and weighs about 3.75 pounds.
a 85 link 630 non-oring EK brand chain is approximately 63.75 inches long and weighs about 4.78 pounds.
So the weigh savings is roughly 1 pound for the 530 vs 630 non-oring EK brand chain, and considering that it takes power to put and keep the chain in motion and to stop the chain - every pound counts. Ed
- pbmax
- zukdave
- Thank you received: 229
Lighter chain also help's with braking.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
