Z1R Front Master Cylinder Rebuild Kit Substitute
- DOHC
- Those Doe-Hawks really go!
Re: Z1R Front Master Cylinder Rebuild Kit Substitute
26 Sep 2014 14:43weales wrote: If I still have trouble I'll have a go at D3's suggestion to elevate the calipers above the m/cyl. (Bit hard to get the T-junction elevated as it's an integral part of the m/cyl...
The lack of a splitter/T-junction actually should help, as this is one less piece where a bubble can hide.
I finally found my micrometer. The wire I used as a gauge pin measures 0.0181", just as the amazon review suggested.
The relief hole would be a tiny bit bigger than this. Rounding up to the nearest fractional millimeter, 0.5mm would be 0.0197". I'd buy that...
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: weales
- weales
28 Sep 2014 14:31 - 28 Sep 2014 15:47
Ok - I will be getting a carb jet tool this week so will clean out the relief hole to that dimension (ie 0.5mm) The hole that I have poked through with a needle is about half this, so it's obviously still got some junk jammed in it! Will post an update on progress - either positive
or negative
I'll be buying a set of digital calipers as well to help with this little task - I've been promising myself one of these for a while now - have been getting by with borrowing one. They are a very handy tool and local auto parts outlets have them for around $30 (although if you want the "Rolls-Royce" version the sky's the limit).
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
Last edit: 28 Sep 2014 15:47 by weales. Reason: Add detail
- Godffery
16 Oct 2014 19:28
Just wanted to give a shout out for member D3: regarding his new Z1R Master diaphragms.
Got'm, Love'em, Worked Great, Thank you very much !
Godffery
tinyurl.com/yfrw4fc
tinyurl.com/yfrw4fc
- weales
05 Nov 2014 13:23 - 05 Nov 2014 19:02Godffery wrote: Just wanted to give a shout out for member D3: regarding his new Z1R Master diaphragms.
Can thoroughly add my thanks to D3 - and all who have contributed to this thread! You guys have helped me heaps with my brakes rebuild! - yes finally got the front brakes assembled and bled successfully! :woohoo:
I've been persevering with the bleed but with no success - even after opening the blocked relief port and re-assembling the whole shebang VERRY carefully per the w/shop manuel. Last night I was about to cover her up again and have a beer when I noticed that the lever wasn't coming right to the h'bars. So, I adjusted this (the Z1-R has a cable operated, remote m/cyl) and had another go (I also gave both calipers a bit of a work back and forth as they hadn't moved even a poofteenth of an inch).
This time a lot more air bubbles appeared in the bleed hose, which was promising and the caliper I was working on actually moved onto the disc and I got some resistance at the lever. I thought "gotcha,!" I bled the other side and hey, hey more air bubbles then clear fluid from this side too, with really good pressure at the lever! I let it sit for a while to savour the success, then bled a bit more fluid through - just to confirm and all was good.
Glad I didn't have to elevate the calipers above the M/Cyl as this would have been pretty tricky in my Un-TARDIS workshop (ie actually smaller once you get inside!). Anyway, I still have a cheesy grin on my face ! Cheers all,
Bill.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
Last edit: 05 Nov 2014 19:02 by weales. Reason: add detail
- Godffery
07 Nov 2014 01:39
Everyone usually likes to see pix, so here are a few of the set I rebuilt with the help of D3's parts.
Godffery
tinyurl.com/yfrw4fc
tinyurl.com/yfrw4fc
- neighbourdave
26 Jan 2015 05:10 - 26 Jan 2015 05:15Attachment IMG_20150126_080644.jpg not found
Great info. I am just starting to tackle this job now.
The bleed hole on my master is plugged also.
I am going to order the parts from Z1 and D3.
Thanks guys.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
Last edit: 26 Jan 2015 05:15 by neighbourdave.
- GregZ
30 Mar 2018 07:55
Vary helpful older thread, thanks to everyone who posted on here..................But I need some help
Last year front brakes worked fine. Over the long winter I move bike and front brakes lock up. I rebuilt everything on front brake assembly per this thread. Bleeding, I get nice clean fluid out of the left front caliper and nothing from the right. Not even a drop of brake fluid at the M/C port, nothing. I can put finger over hole and pump brake lever and there will be a suction at my finger but no fluid. not a drop. I'm stumped
- Godffery
30 Mar 2018 09:16I would think the only way for one side to work and the other Not, is a straight up clog in that junction? Still, that would be the first time I ever herd of that happening.?!GregZ wrote: Vary helpful older thread, thanks to everyone who posted on here..................But I need some help
Godffery
tinyurl.com/yfrw4fc
tinyurl.com/yfrw4fc
- DOHC
30 Mar 2018 10:27GregZ wrote: I can put finger over hole and pump brake lever and there will be a suction at my finger but no fluid. not a drop. I'm stumped
I agree that a clog seems like the most likely explanation. I know I had a front brake line that was so clogged that nothing came out of the far end.
If it would help, I have a spare Z1R master cylinder I can dig out to try to figure out what the fluid path looks like between the bore and splitter. But it may take me a few days to find it.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- GregZ
30 Mar 2018 13:53
Almost 8 hours on it today. Completely frustrated I don't have a clue
30 Mar 2018 14:02
Line collapsed causing the clog?
30 Mar 2018 15:22
