18" Rear Wheel on LTD 1000?
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
24 Aug 2012 08:55
#544451
I'm thinking about picking up an LTD 1000 but really prefer an 18" rear wheel....can that be done without any problems on the '77 to '80 models? I wonder how an LTD would look with the 18" wheel....should look like the A model, I would think. I don't think there's much of a frame difference other than the rear peg / exhaust mounts is there? I'm thinking rear caliper and rotor might be smaller on the 16" but not sure. Any other issues to look for? I would be replacing the 16" wheel with an 18" wheel from another KZ...either a stock MKII rear wheel or maybe a '77/'78 A model hub with a custom rim. Thanks
The Kaw List:
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: 18" Rear Wheel on LTD 1000?
24 Aug 2012 08:57
#544452
My experience, same rotor and caliper size. Should just slide right in and I agree, 18's are a better setup.
Les
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
24 Aug 2012 09:44
#544457
I installed a Mark II rear wheel on my A4 and had to change the rotor. The Mark II rotor is larger and won't allow the stay rod to connect. The stay rod hit the top of the rotor.
  • 79MKII
  • Love Them Kaws!
24 Aug 2012 10:21 - 24 Aug 2012 10:23
#544461
My thoughts on the rear rotor came about when I cross referenced the part numbers for my friend. I compared the 1980 B4 LTD vs. the 1979 A3 MKII....different part number although the rotors look identical to me. I have a spare set of MKII wheels including the rear caliper and master cylinder, brake stay...even swingarm and shocks now that I think about it....but worse case I would probably have to put the MKII caliper on with the MKII rear wheel and be fine.
I know the rear sprockets are different too....33 teeth on the B models vs. 35 teeth on the A models.
The Kaw List:
Last edit: 24 Aug 2012 10:23 by 79MKII.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
24 Aug 2012 10:28
#544463
Cool, didn't know that a MK11 was bigger. Good thing to know!
Les
  • pete greek1
  • pete greek1's Avatar
24 Aug 2012 14:13
#544515
same thing with the 78 Z1 rear rotor, it was about a 1/4 inch bigger than my LTD rotor, so I had to buy a 78 Z1 caliper, the front Z1 rotors were the same size as the LTD rotors, so no problems there...Pete
  • OldSchoolZ
  • OldSchoolZ's Avatar
25 Aug 2012 15:03
#544724
I just hate how darn skinny they are. Nothing screams antique like a 2 inch rim lol
Remember, don't work on your bike so much you never ride it.
  • Je77ekz1000a
  • Je77ekz1000a's Avatar
25 Aug 2012 15:24
#544728
Here you go, Old school Z.
18in wheel thats NOT skinny!
Jesse Shasteen
77 KZ1000 A
Huntsville AL
  • Je77ekz1000a
25 Aug 2012 15:26
#544729
Jesse Shasteen
77 KZ1000 A
Huntsville AL
  • Je77ekz1000a
25 Aug 2012 15:32
#544732
Jesse Shasteen
77 KZ1000 A
Huntsville AL
  • RonKZ650
  • RonKZ650's Avatar
26 Aug 2012 01:49
#544805
roy-b-boy-b wrote: I installed a Mark II rear wheel on my A4 and had to change the rotor. The Mark II rotor is larger and won't allow the stay rod to connect. The stay rod hit the top of the rotor.
Like I said before the MKII in 79 and the A4 in 80 used the exact same rotor. 79-80 KZ1000 A series used the same rotor exactly. Now, putting a decent 18" wheel in place of a dumbass 16" I don't know, but sure worth a try. :P
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
27 Aug 2012 01:44
#544993
What year LTD are you looking at?
I know the '78 LTD uses a different rear caliper than the KZ A2. It is smaller for the LTD. Not sure about rotor diameter for the '78 LTD.
The rear rotor on my '80 LTD is 1/2" smaller in diameter than the '78 KZ A2 rear rotor. That tells me the rear caliper may be(should be) spaced different from the axle center line to the pad location. Hope all that doesn't confuse you too much :silly:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
