Tuesday, May 21, 2013
Text Size
Username Password: Remember me
Banner
Why a 520 conversion
(1 viewing) (1) Guest
  • Page:
  • 1
TOPIC: Why a 520 conversion
Why a 520 conversion 2 years, 6 months ago #409771
why do super bikes convert to a 520 and we worry about the strength of the chain when a super bike puts out more power than a lot of built bikes do? i am a 530 convert and was wondering why not just go to 520?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Re:Why a 520 conversion 2 years, 6 months ago #409792
i have been rolling a 520 for several thousand miles now and never had any worries,or problems.
for me there is no reason not to do it.
Re:Why a 520 conversion 2 years, 6 months ago #409819
  • Becker
  • OFFLINE
  • The Doctor Will Rise Again
When our bikes were new they came with 630 chains because they needed the bigger chains to deal with their horspower output. Since then chains have become much stronger and they stretch much less. so going from a 630 chain to a 530 chain is perfectly acceptable and there is a big difference in the weight of the 2 chains and since they are rotating mass this weight means more then stationary wieght. lighter chain equals better acceleration. That being said the difference between 530 and 520 isn't that much so I don't know how much it would mean.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Re:Why a 520 conversion 2 years, 6 months ago #409820
  • testarossa
  • OFFLINE
My ZX-10r puts about 160 hp to the ground, and runs a 525 chain. I don't see why a 520 wouldn't work for a KZ that might put 65 hp to the ground in stock form. Just get a good quality o-ring or x-ring chain.
1982 CB750F
2004 ZX-10R
Spring, TX
Re:Why a 520 conversion 2 years, 6 months ago #409851
You can run a 220 chain if you don't mind replacing it every 500 miles:) 630 lasts a good long time because it's big and tough, a 530 lasts a certain percentage less, a 520 a certain percentage less yet. Stay big and tough is my advice. I really don't care a 150hp ninja has a 520 chain, they are made for speed, not longevity. Be a dark day in hell I get rid of the stock chain and put on a bicycle chain. Of course I'm biased to stock trim in paint and all else and stuck in my way for 40 yrs, you kids can run bicycle chain and gain that extra 1/2 HP.
Re:Why a 520 conversion 2 years, 6 months ago #409855
  • OFFLINE
  • Many Thanks, Stein!
RonKZ650 wrote:
...[some stuff about chains]....
In Ron's corner here, preferring the big gnarly macho 630 chain as God and Kawasaki intended.
And not some sissy little girl's chain (like OMR's).
Re:Why a 520 conversion 2 years, 6 months ago #409858
  • OFFLINE
Interesting, because my GB500 has oem 525 size chain.
Thinking sort of an unusual size.
Re:Why a 520 conversion 2 years, 6 months ago #409859
i'm with ron and patton here.
Re:Why a 520 conversion 2 years, 6 months ago #409860
I run a 530 on my 1105 and have had no issues in the 2 years I've been running it. I have only had to adjust it 3 or 4 times in that time and I've put probably 25K miles on it. The fact is that the newer chains have a much higher tensile strength than the chains that originally came on our bikes. The RK GB530GXW that I have has a tensile strength of 10,000 lbs and is rated for bikes up to 1400cc and is recommended as a replacement for the Hayabusa. The strength is there and it saved a lot of weight on my bike. Not to mention it was a lot easier for me to get a rear sprocket for my rear wheel in a 530 so I'm glad that I made the switch.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Re:Why a 520 conversion 2 years, 6 months ago #409871
every body has very good points here...
IMO If you have a stock swing arm and tire, there is no reason to change from a 630, not a really big performance jump and over all pretty close to the same replacement cost as either a 530 520.
I just changed to a 520 from a 525 because like dejavoodo41 it was cheaper and easier to find for my wheel. It also clears the frame with my offset with no mods
And like testarossa I have a 05 zx10r with over double the H.P. that came from kawasaki with a 530 or 525.
So the same people that designed our vintage beasts decided that something with double the power didnt need the huge chain anymore...
A team of little ninja's cant be wrong
All in all as long as its street rated and a reputable company I think imo stock should be stock not stock do what ever works with your project
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Last Edit: 2 years, 6 months ago by jayw704.
Re:Why a 520 conversion 2 years, 6 months ago #409883
Does a 1/2 horse make that much difference on a 650? I don't think it would on a 1000 anyway the longevity makes sense. I guess i should have named the thread why not a 520 conversion.
1980 kz1000G1
Re:Why a 520 conversion 2 years, 6 months ago #409885
all kidding aside thanks for the different perspectives (they seem to have their advantages and disadvantages)
thanks again
thius board has helped me a ton over the time i have beeen working on bikes. keep it up
1980 kz1000G1
Re:Why a 520 conversion 2 years, 6 months ago #409897
  • testarossa
  • OFFLINE
Ron, I don't disagree that a 630 chain is a very good choice, but I do have one problem with this line of thinking. The only difference between 630 and 530 is the pitch or length of the links. Both use 3/8" wide sprockets, and most of the higher end 530 chains are rated to a higher tensile strength than what is available in 630 since none of the high powered bikes use 630 any more. 530 also has more teeth on the same diameter sprocket than 630. More teeth distributes the load better IMO.
Now with that said, 520 uses 1/4" wide sprockets and so the chain is slightly more narrow. This may lead to somewhat faster wear since the load is now distributed to the 1/4" sprocket and shorter rollers.
I will agree that if you try and run a significantly smaller chain than stock, you could expect a shorter life. I think that the most crucial factor influencing chain life is proper maintenance. I clean and lube the chain on my bikes at least every 500 miles, and I keep the tension adjusted by the book. The ninja has 10,000 miles on the current 525 chain, and I just had to adjust the length for the first time. I still cannot see any appreciable wear on my sprockets, so I believe that I can go the better part of 10,000 more. I have been through 3 back tires in the same amount of time.
IMO chain wear occurs primarily from grit working it's way into the rollers and wearing the insides. Keep it clean and it will last.
Yes Patton, the 525 is an oddball. I'll probably switch to the more common 530 at the next change. FWIW, almost all the guys who switch to 520 on a liter bike are either drag racing or street racing, and for them 1/2 hp does make a difference. Any extra hp equates to more top end speed, and especially for the street racers who are often at the limit, even 1 mph advantage is the difference between getting "walked" and "walking" I do not encourage this activity.
1982 CB750F
2004 ZX-10R
Spring, TX
Re:Why a 520 conversion 2 years, 6 months ago #409903
"And not some sissy little girl's chain (like OMR's)."...
Now damn it Patton, I have a beefy 630 O-ring on mine and have no intention of changing it thank you much...
Mine stretched ~ 1/4" initially and I have not had to adjust it since... And yes, I check/lube it regularly especially before 200 mile breakfast runs we do up the hill...
If I require a .5 to 1 hp gain for a run, I'll skip lunch. Ah hell, my beast has more then enough power where she doesn't even know I have a full belly so a 1 hp gain on a street ride, not a big deal...
NOTE: For the drag/racing bike folks out there, you bet, I get it where every ounce counts and where mass weights/torques and milli seconds shaved in a run translates into a win or loss.
As for all the purdy colors available on the 530 series (chains and sprockets), not for me...
As mentioned, keep to KZ spec tensile strengths and you'll be ok or be prepared to spend the $$$ replacing every couple thousand miles or sooner pending how you ride her (cruise versus hammering the throttle)...
Regarding costs... A 9k-10k tensile strength chain (EK ZZZ O/X-Ring series) can run ya about $150 plus.... My 630 O-ring was around a $100...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
Keihin, 29mm CR specials
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Re:Why a 520 conversion 2 years, 6 months ago #409919
Guess I am Old School, 630 for me.
Have 1975 Kawasaki Z1-B
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Re:Why a 520 conversion 2 years, 6 months ago #409927
I'm with Tessarossa on this.
If you spend the same dollars - the 530 chain will last longer than 630 chain.
630 O-ring and 530 x-ring are about the same price - the x-ring will outlast the o-ring on most bikes (or should I say in the hands of an average rider how only occasionally maintains the chain).
The availability of 530 chain is a reason to switch if you take long rides - not many bike shops stock 630 chain - so if you need to replace a chain on the road, the 530 will be in just about all bike shops.
520 will wear out quicker than 530 due to the width of the rollers and the more wear on the sprocket teeth.
This e-mail address is being protected from spambots. You need JavaScript enabled to view it
http://www.z1enterprises.com
Z1 Ent on Facebook, 1200cc Turbocharged 1973 Kawasaki Z1, 1974 Z1A, two GS1000 and more...
Re:Why a 520 conversion 2 years, 6 months ago #409928
Jeff, I've read the Z1E chain conversion guide, still finding it a little difficult to go through the website and find the proper sprockets for converting a KZ1000 to 530.
I wonder if you might list the part numbers here so some of us can quickly locate the correct sprockets to order along with a chain?
Thanks, Mike
1978 KZ1000, 1976 KZ900, 1975 H2, 1973 H1, 1985 RZ350 (sold 2013), 1979 KZ1000 LTD (sold 2012)
Hawaiihomes1.com
Re:Why a 520 conversion 2 years, 6 months ago #409931
  • OFFLINE
Re:Why a 520 conversion 2 years, 6 months ago #409932
I love my 530 chain conversion on my GPz1150 It is way outlasting my old 630 on my stock 900. The 520 chain will give you about 66% of the life of the 530, or there abouts. the problem i found is the sprocket availability for our bikes in the 520. 530 are available everywhere.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Re:Why a 520 conversion 2 years, 6 months ago #409955
Thanks, Mike
530 is 5/8" pitch, 630 is 6/8" pitch
So to convert 630 chain and sprockets to 530 multiply the tooth count and chain links by 1.2 (6 divided by 5).
15t becomes 18t
33t becomes 39.6 rounded to 40t
92 link becomes 110 link
If you want more of a cruising setup, go slightly smaller on the rear.
For more acceleration go larger on the rear.
Generally keep any gearing change to just 1 or 2 teeth on the back.
The first thing to always do is check what is on the bike today. If a previous owner changed the sprocket combination, you may reorder stock equivilent sprockets and get a surprise when the gearing is way different than you expected.
  • Page:
  • 1
Banner
Time to create page: 0.50 seconds
