Shaft drive gear ratio change
- dxhemen
07 Apr 2010 11:41
Hello, I am trying to gather info around the possibility of changing a gear ratio in my '83 Spectre 1100 SHAFT DRIVE.
I want to lower my freeway RPM for more comfy cruising.
At 75 mph it is in the high 3800-4000 range and too noisy.
I have the 130/90 tire also.
Would anyone have any ideas.
Thank you,
David H
Thank you,
David H
- OKC_Kent
Re: Shaft drive gear ratio change
08 Apr 2010 10:53
This would be a difficult change, and I don't really have an answer for you, sorry. But I didn't want you to think your question was being ignored, it's just something most of us (I think) would not attempt. I would think a machine shop would come in handy about now.
The easiest way would be to install a taller tire, but you won't gain much rpm drop. What is noisy, exactly? Engine noise, or exhaust?
Cashion, OK
78 KZ650 B2 85,000+ miles
- Bluemeanie
08 Apr 2010 20:54I want to lower my freeway RPM for more comfy cruising.
I'm pretty sure there are no existing gear swaps for shaft drive. But I don't understand what is so noisy? My KZ650 is doing almost 6500 rpm at 75 and you want to talk buzzy!! I would think 3800-4000 rpm would be pretty nice on the freeway. I'd be happy with 5000 rpm at 70!
- Old Man Rock
09 Apr 2010 06:04
"I would think 3800-4000 rpm would be pretty nice on the freeway"... No doubt!
In my setup, 5th gear at 75mph is spot on at 5500rpm...
Not complaining for my engine build with 15/37 sprocket combo is where I want my power band... Mid range!
Seems at cruising rpm yours has, should be just right. Shaft noise or exhaust?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- T_Dub
09 Apr 2010 06:10
Yeah I'm the same as Bluemeanie. The PO of my 650 has taller sprockets on, and I changed back to stock to get more acceleration. And now she revs very high on the highway. But my bike isn't for cruising so I don't care too much. 4000RPM is so smooth on these bike, can't see why you'd want to go lower.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- otakar
09 Apr 2010 07:11 - 09 Apr 2010 07:18
I went the other way around from most of you guys on my GPz1150. I feel that i have power to spare, and I wanted a good top end. When I converted to my 530 arrangement from the 630 I installed a 18t front and a 40t rear sprocket. In 5th gear and 4200rpm I am doing 79mph according to the GPS In fourth gear and 8200rpm I am doing 136mph. I am at 109mph at 5800rpm in 5th. This should give me a theoretical top end of 169mph at 9000rpm.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 09 Apr 2010 07:18 by otakar.
- otakar
09 Apr 2010 07:15
If you have not used this, try it it is great. All the info you need to plug in is in your Kawasaki manual, and on your rear tire.
www.gearingcommander.com/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
09 Apr 2010 16:41 - 09 Apr 2010 16:42
Well not much he can do about it without some fairly in-depth internal gear changing...or am I wrong here....
Possibly with some different cams may be able to shift the rpm ranges a little but.... to what effect, probably not much...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 09 Apr 2010 16:42 by Old Man Rock.
- PLUMMEN
09 Apr 2010 17:10 - 09 Apr 2010 17:27
try a 140/90 tire.should give you roughly an extra 9mm on each side of rim basically raising gear ratio just a tad to lower rpms a little.
ill let the engineer types figure the exact numbers! :laugh:
Last edit: 09 Apr 2010 17:27 by PLUMMEN.
- KZ1100 Bully
12 Apr 2010 11:11 - 13 Apr 2010 11:03
Hi, my 1983 kz1100 spectre runs 75mph is spot on at 4400rpm. You might want to double check that your gauge is working right. My bike is well maintained and running great. Has lots of power left at 75mph and does not seem like it is having a hard time maintaining that speed. Just the opposite it wants to go faster.
1983 Kawasaki KZ1100 Spectre D2
Last edit: 13 Apr 2010 11:03 by KZ1100 Bully.
- dxhemen
14 Apr 2010 07:41
Thanks Kent,
I appreciate the info. It sounds like 3800-4000 isn't too bad by some other folks out there.
My main complaint was the buzz through the bars and grips, which are old hard originals. I should probably try some new ones.
Thanks again.
David H
Thanks again.
David H
- dxhemen
14 Apr 2010 07:44
Thanks for the input.
I must be too used to autos at 2000 at 75mph.
It was really the handle bar buzz making me numb.
Some new grips may help.
Thanks again.
DH
Thanks again.
DH
