master cylinder rebuild kit for '81 KZ550?
- Colossus
27 Jan 2010 22:26
I've been searching but the only kits I can find are for '82s and up. Could any of you point me in the right direction?
1981 KZ550A2
- MFolks
Re: master cylinder rebuild kit for '81 KZ550?
27 Jan 2010 22:43
Asked at
www.z1enterprises.com
? they could tell you if the parts interchange.
- Colossus
27 Jan 2010 23:05
Thanks for your help but I bought one from them about six months ago and it doesn't fit. Gonna need one for my year or before I'm afraid. Guess I could call them in the morning and see what they have to say. I never tried to return it or anything.
1981 KZ550A2
- GPz550D1
28 Jan 2010 08:36 - 28 Jan 2010 10:14
You can look on the bottom of your master cylinder and there should be a 1/2 or 5/8 cast into the bottom of it. This is the size of the piston bore of your cylinder. Both kits should be available, although I had a hard time locating the "1/2" kit. If you have any further questions, please post this number from your master cylinder and we will try to find the correct kit part number. Also, please let us know if you have a KZ550-A2 or another model.
Robert
Robert
1981 KZ550-D1
Last edit: 28 Jan 2010 10:14 by GPz550D1.
- Colossus
29 Jan 2010 14:41
Hey that was solid advice. First I'd heard of that. It's a 1/2" inch bore and my model is an '81 KZ550 A. The dude I bought it from said it was a 550 C but on the frame and pipes it says A. I'll go with that. Where did you find your 1/2" kit?
1981 KZ550A2
- GPz550D1
29 Jan 2010 15:33 - 29 Jan 2010 15:42
Sorry, I can't locate a kit for your bike at the moment. The Kawasaki piston and seal assembly, part #43020-1027 has been discontinued. Here are the models that have the same piston and seal assembly as your bike.
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-G1 (LTD II) (1980)
KZ750-M1 (CSR Twin) (1982)
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ650-F1 (1980)
1981 KZ550-D1
Last edit: 29 Jan 2010 15:42 by GPz550D1.
29 Jan 2010 16:51
29 Jan 2010 17:10
Might check out this supplier.
speedsupplies.com/partslisting.asp?posit...ment=500&category=KW
Part Number Description Quantity Retail Sale Price Extended
43020-1027 PISTON-COMP-BRAKE $60.20 $54.18 $54.18
Subtotal: $54.18
A m/c may sometimes be restored to serviceable condition using the existing piston and cups, where the bore isn't too badly pitted.
Good Luck!
Subtotal: $54.18
Good Luck!
- GPz550D1
29 Jan 2010 19:59
The '81 KZ440-A2(LTD) has a master cylinder that is very similar to yours. The retainers and seal in the end of it have the same part number as the ones on your master cylinder. It is possible that it is also a 1/2" bore cylinder, since this bike also has a single disc brake in the front. The piston and cup assembly for it are still available, Kawasaki part #43020-1026. The piston is likely different from yours, but it is possible that the rubber cups can be taken off the new one and installed on your old piston. I realize that this is not the ideal scenario, but if you get desperate, this might be something to look into. Sooner or later you will find the correct part. As Patton says, you can sometimes get your old master cylinder to work by taking it apart, cleaning and putting it back together. I like to take the old cups off the piston and clean out the groves real well, then put them back on. This seems to stretch the cups out a bit and can help it to seal until you find something better to work.
Robert
Robert
1981 KZ550-D1
