frame bracing
  • gershom
  • gershom's Avatar
Re: frame bracing
02 Jun 2009 12:22
#295791
Interesting that they say:
"remember not to weld directly to the frame as the bracing must be forged in"
What exactly are they trying to state? Maybe, they are afraid that if people weld the frame will twist? Most don't have a frame jig to use to keep the frame from twisting while welding.
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: frame bracing
02 Jun 2009 12:34
#295796
I dunno, but they've always had a great reverence for steel and its properties.
  • KawiConvert
  • KawiConvert's Avatar
Re: frame bracing
06 Jul 2009 09:27
#304730
I believe they are refering to heat treating the final frame. If you weld without heat treating the metal is brittle at the weld and additional stresses are introduced into the metal. This leads to twisting if the stresses are high enough compared to the strength of the frame.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • judgie
  • judgie's Avatar
Re: frame bracing
09 Jul 2009 03:41
#305581
all this info and it seems no one bothers doing it to a 650 frame. this becuase the 650 dont haev the power to twist the frame? also the 650 frame seems to have a slightly differant frame to the one above.
cheers rob
forever tweeking aircooled engines, well it is my job
77 z650c1
  • KawiConvert
Re: frame bracing
09 Jul 2009 10:12
#305651
It may be due to limited power of the 650, or due to people who want to push a bike that much stepping up to a larger bike. Either way, the bracing would have a similar effect on the smaller bikes. The locations might need to be changed somewhat for optimal effect. But we are talking about a 30 year old bike so I doubt they did that much optimizing beyond ensuring a sufficient factor of safety was ever done by MaKawi. One of the reason that the old bikes are still around and holding up versus new bikes with cracked frames and such.
I am debating bracing my 650 as I am planning to throw a gpz750 engine in my 650. Though, I am planning to either brace or replace the swingarm with something stronger. That is one area to brace on the 650 that pays as the tube design allows for twisting.
  • mzandmz
  • mzandmz's Avatar
Re: frame bracing
08 Aug 2009 08:10 - 08 Aug 2009 08:12
#312372
My center stand is bent I think. The foot lever rest on the ground,and the angle if the main rest is wrong. I think it should set flat. Plus it hits the tire when I put it down.Doesnt rub when up.
New to Family, 1979 KZ440 LTD
Last edit: 08 Aug 2009 08:12 by mzandmz.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: frame bracing
08 Aug 2009 11:22
#312414
i would think it would be hard to bend a center stand but anything is possible i guess.id check the mounting brackets and bolts B)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: frame bracing
10 Aug 2009 09:14 - 10 Aug 2009 09:20
#312944
The 650 was braced better around the steering head than the big kzs. Adding some braces in simialr areas as mentioned above couldn't hurt, like in front of the engine between the two downtubes, and below the side cover in the V of the frame like on this kz650:
The stock swingarm can be braced similar to how I had mine done, keeping stock wheelbase and mods (swingarm pivot, shock mount etc etc) to a minimum. I did have to loose the center stand and mounts:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 10 Aug 2009 09:20 by rstnick.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: frame bracing
10 Aug 2009 11:25
#312952
It's not quite as beefy but I braced my Z1 with this kit from PMC (Z1E can order it for you)
It's a one kit fits all frames type of thing so there were a few extra bits and my frame already had a brace behind the engine but it's not a bad kit overall
79 KZ1000ST
Past:
Many.
  • pz1morton
  • pz1morton's Avatar
Re: frame bracing
03 Sep 2010 17:20
#395913
Hi Leon
Any chance you could send that file to me.thanks.
Regards Paul
pmorton@rogers.com
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
  • Pfaelzer
  • Pfaelzer's Avatar
Re: frame bracing
07 Sep 2010 16:20
#396858
Leon,
if you don't mind - could you send me the file also?
Careyvrs@msn.com
thx
bernhard
1977 KZ 1000
Queen Creek, Arizona
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Vendor
Re: frame bracing
08 Sep 2010 08:46
#397025
sent to both emails.
