frame bracing 09 Jul 2009 10:12 #305651
  • KawiConvert
  • KawiConvert's Avatar
  • Thank you received: 4
It may be due to limited power of the 650, or due to people who want to push a bike that much stepping up to a larger bike. Either way, the bracing would have a similar effect on the smaller bikes. The locations might need to be changed somewhat for optimal effect. But we are talking about a 30 year old bike so I doubt they did that much optimizing beyond ensuring a sufficient factor of safety was ever done by MaKawi. One of the reason that the old bikes are still around and holding up versus new bikes with cracked frames and such.
I am debating bracing my 650 as I am planning to throw a gpz750 engine in my 650. Though, I am planning to either brace or replace the swingarm with something stronger. That is one area to brace on the 650 that pays as the tube design allows for twisting.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
frame bracing 08 Aug 2009 08:10 #312372
  • mzandmz
  • mzandmz's Avatar
  • Thank you received: 0
My center stand is bent I think. The foot lever rest on the ground,and the angle if the main rest is wrong. I think it should set flat. Plus it hits the tire when I put it down.Doesnt rub when up.
New to Family, 1979 KZ440 LTD
Last edit: by mzandmz.
frame bracing 08 Aug 2009 11:22 #312414
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
i would think it would be hard to bend a center stand but anything is possible i guess.id check the mounting brackets and bolts B)
frame bracing 10 Aug 2009 09:14 #312944
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
The 650 was braced better around the steering head than the big kzs. Adding some braces in simialr areas as mentioned above couldn't hurt, like in front of the engine between the two downtubes, and below the side cover in the V of the frame like on this kz650:
The stock swingarm can be braced similar to how I had mine done, keeping stock wheelbase and mods (swingarm pivot, shock mount etc etc) to a minimum. I did have to loose the center stand and mounts:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
frame bracing 10 Aug 2009 11:25 #312952
  • KZ250LTD
  • KZ250LTD's Avatar
  • Thank you received: 16
It's not quite as beefy but I braced my Z1 with this kit from PMC (Z1E can order it for you)
It's a one kit fits all frames type of thing so there were a few extra bits and my frame already had a brace behind the engine but it's not a bad kit overall
79 KZ1000ST
Past:
Many.
frame bracing 03 Sep 2010 17:20 #395913
  • pz1morton
  • pz1morton's Avatar
Hi Leon
Any chance you could send that file to me.thanks.
Regards Paul
This email address is being protected from spambots. You need JavaScript enabled to view it.
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
frame bracing 07 Sep 2010 16:20 #396858
  • Pfaelzer
  • Pfaelzer's Avatar
Leon,
if you don't mind - could you send me the file also?
thx
bernhard
1977 KZ 1000
Queen Creek, Arizona
frame bracing 08 Sep 2010 08:46 #397025
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Thank you received: 797
sent to both emails.
frame bracing 29 Jan 2011 07:04 #426730
  • 531blackbanshee
  • Vendor
back to the top.
had some folks ask about frame bracing so i thought that i would bump it back up.
Last edit: by 531blackbanshee.
frame bracing 29 Jan 2011 16:51 #426849
  • 531blackbanshee
  • Vendor
how about these removable lower motor mounts?:)
frame bracing 29 Jan 2011 16:55 #426851
  • 531blackbanshee
  • Vendor
this guy replaced the lower frame tubes.
frame bracing 29 Jan 2011 16:56 #426852
  • PLUMMEN
  • PLUMMEN's Avatar
whats the reason behind those,raise lower motor? B)
