frame bracing 06 Sep 2014 07:46 #646397
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Nice job JCW
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
frame bracing 30 Oct 2014 07:06 #652207
  • Mcgoo
  • Mcgoo's Avatar
  • Thank you received: 0
Great thread! - pretty soon I'm going to have everything off my frame and I'm considering doing some bracing at that time.
I don't have cheap access to a TIG - I can MIG, but I get that it could cause issues.
Would brazing be strong enough? That to me is probably the most accessible way of doing this, but if it's not strong enough there's no point in doing it.
Thanks
Iain
Last edit: by Mcgoo.
frame bracing 30 Oct 2014 07:27 #652209
  • NakedFun
  • NakedFun's Avatar
  • Thank you received: 99
Mcgoo wrote: Great thread! - pretty soon I'm going to have everything off my frame and I'm considering doing some bracing at that time.
Thanks
Iain
Brazing will be just fine, but so will MIG. Since you have access, your could also Oxy-Acetelene weld as well with the right steel rod. Long story short, any weld method will work just fine if you know what to do with the method you use and take the appropriate precautions. The thing about bracing is that you are simply adding ridigity, so in my mind they are slightl less critical joints when compared to actually welding the main tubes together. Also if you are unsure, take some scrap tube that is the same thickness and practice your technique and setting until you are comfortable. I tend to do this when it has been a while between welding, then my vise, big a$$ hammer, and anvil get a working as I try and break the weld. If it doesn't break no matter what I do, I know I am set to burn I the actual pieces. Also, FWIW I MIG'd my frame modifications for various reasons....
Good luck with what ever you choose.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
The following user(s) said Thank You: PLUMMEN, 531blackbanshee, Mcgoo
frame bracing 04 Nov 2014 17:08 #652881
  • kaw-a-holic
Thanks
Iain
Norton frames used to only be brazed. I wanted to do it that way just for bragging rights but its my only bike so I did not want to take the chance. I have not used oxy/acl in a long time. My brother has a Cobra Torch which is a much better way to braze. It uses a 1/4 of the heat but does the same job. What ever you do make sure you share your experience and get us some pics.
Jon
1977 KZ1000a1
Mesa, AZ
The following user(s) said Thank You: PLUMMEN, Mcgoo
frame bracing 04 Nov 2014 17:22 #652887
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
These poor frames are already so overstressed from the original mig welding ,brazing will not stress the frame the way mig welding does,if anything Id say it may help distress the frame if done properly. ;)
The following user(s) said Thank You: Mcgoo
frame bracing 05 Nov 2014 13:45 #652956
  • CruisingRam
  • CruisingRam's Avatar
  • Thank you received: 15
PLUMMEN wrote: These poor frames are already so overstressed from the original mig welding ,brazing will not stress the frame the way mig welding does,if anything Id say it may help distress the frame if done properly. ;)
I have to respectfully disagree with you Plummen- I did extensive lab testing on the metal of these frames in 2008, and there are a lot of issues- but not the welds really. This is what I found in the lab:
1) The metal is extremely "dirty"- lots of contaminates. Lots of silica in it.
2) It is welded tube- NOT DOM. it appears that they oriented the welds to face each other- don't know if this was intentional or just part of the industrial process as they came off the machine- for instance, the swing arm welded tubes, the welds faced each other to the inside. I did not even see the welds, I guess they were so old or something- even after sandblasting. I sure did see them in x-ray though.
3) The pipe/tubing that they used would not pass inspection entities in the US today.
The worst thing about any welding process would be deforming due to heat. Tig obviously would be the better process in that regard. I did my frame and had no deformation at all. I also did mine in a frame jig, locked down tight! I used a mig, and also x-rayed, magnafluxed and even did some electron microscoping and mass spectrometer testing on some bits of my frame. Fun to be in school back then- let me tell you LOL
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
The following user(s) said Thank You: bluezbike, NakedFun
frame bracing 05 Nov 2014 17:45 #652972
  • NakedFun
  • NakedFun's Avatar
Cruise,
When you did your analysis, what did you find the main tube wall thickness to be?
Cory
1976 Kawasaki KZ900
frame bracing 05 Nov 2014 19:04 #652982
  • PLUMMEN
  • PLUMMEN's Avatar
Welding puts stresses on the metal from the heat of the welding,and as it cools it tries to pull in different directions.
Back when I did foundry work I talked to the plant engineer about coming up with a really stout jig to tie a frame together with then shove it into the oven where they heat treated castings .
The plan was to heat it to a pre determined temp for a certain amount of time then cool it down slowly to "destress "
the frame.
Its the same reason they use frame jigs when building a frame to help control distortion from the welding and cooling of the materials. :)
The excessive heat of the welding also makes the material more brittle,same reason why you should never weld straight up and down the side of a car/truck frame,you should put a step or atleast an angle where the 2 pieces of frame are butted back together.
frame bracing 05 Nov 2014 19:07 #652985
  • PLUMMEN
  • PLUMMEN's Avatar
NakedFun wrote: Cruise,
Cory
Very thin! :laugh: Id say it would land somewhere between 14-16g,I make frame braces out of 14g.
With a little practice you can stick weld on these frames :)
frame bracing 05 Nov 2014 19:12 #652987
  • PLUMMEN
  • PLUMMEN's Avatar
frame bracing 05 Nov 2014 19:38 #652993
  • NakedFun
  • NakedFun's Avatar
This is all good information, but I think many people over think this bracing process a bit. The idea of adding some gussets to help add ridigity to the frame is straight forward and can be accomplished in a variety of ways. One of the keys are to minimize the HAZ to the area that you are welding to prevent a crystalline structure shift in the base metal. Basically keep the good property's like strength and ductility in the alloy instead of making it brittle. MIG is actually good at minimizing the amount of heat that goes into the base metal beyond what is needed for proper fusion. This is one reason why it is the preferred method for repairing HSS sections of automobile frames and subframe. No matter what method you use, you are still melting the base and filler metals together. Whether it is straight up OA heat from flame or through arc welding via stick, MIG, or TIG, you need X amount of heat to get fusion based on material, material thickness, and joint type. Go beyond this and you start to get brittleness, material creep/warpage, and cracking.
Unless you simply apply some hammer blows along the weld seam as stated earlier in this thread, all other relief methods are out of the hands of most builders on here, and most likely not needed for the non-critical joints we are doing through bracing. It is not a bridge that need to have proof coupons tested prior to fabrications.
Per Ram's comments, really the poor quality of the material is the weakest link in all of this discussion. Not saying it is so weak that it is not upto the task of being a safe motorcycle frame, but out of the variables of weld type, gusset material, material thickness, etc in the overal structural integrity of the bike, it is the"weakest link".
I don't want this discussion to intimidate new comers to the hobby and make it out to be much more involved than it really is.
Good discussion though.
Cory
1976 Kawasaki KZ900
frame bracing 05 Nov 2014 23:03 #653007
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 665
You could shot peen the frame. I looked into it a while ago and found a company that would do a frame for $250 but i ultimately decided it was overkill.
www.metalimprovement.com/shot_peening.php
