  • Page:
  • 1
  • 2
82 kz250 weak no spark 09 Oct 2015 17:10 #693979
  • Thank you received: 2098
Might be just a weak battery.
Would have battery load-tested, which is usually a free service provided anywhere batteries are sold such as AutoZone, Walmart, etc.
It's best to service the battery and charge it overnight before taking it in for a load test.
As known, a voltage reading of 12 volts between the battery terminals is possible even with a very weak battery.
Will the battery produce a strong bright headlight?
Does the headlight automatically turn on when the ignition switch is turned ON?
Good Fortune! :)
82 kz250 weak no spark 09 Oct 2015 17:52 #693982
  • 82 kz250l
  • 82 kz250l's Avatar Topic Author
  • Thank you received: 0
Patton wrote: Might be just a weak battery.
Good Fortune! :)
Yes the headlight is automatic...an yes it's a bright light ....I'll try another battery thoe
82 kz250 weak no spark 24 Nov 2015 15:55 #700371
  • oldie
  • oldie's Avatar
  • Thank you received: 1
I too have an 82 is 250 which currently isn't getting spark . I figured the way I got the bike with a questionable CDI/idnitikn module/igniter, and bought a used one online (which the seller indicated in his ad that it was a working part) I have voltage to both sides of cool and still no spark also have current at terminals at CDI connection. I'm also baffled.
82 kz250 weak no spark 26 Nov 2015 16:38 #700711
  • 82 kz250l
Try bypassing the kill switch
Have you diagnose the coil?
Check the pickup by the stator
Check the stator
Mine was the cod box. An instead of buying a New one for 150 plus dollars. I went to the local parts store an bought a (pickup control module) for a Chevy hei distrbuter. An wired it in
82 kz250 weak no spark 26 Nov 2015 22:56 #700747
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1634
Also, clean up all of the spark plug wire connections. The ribbed compression boot unscrews from the coil. If there's the white crusty oxidation, nip off the ends of the plug wire a tad. Or go ahead & install a new spark plug wire. I solved an intermittent firing problem by redoing the connections; then latter installed new 7mm copper core spark plug wires & Dyna ignition coils. new spark plugs wouldn't hurt.
PS: don't believe the "working part" stuff --- test it as per the manual. people don't know or flat out lie.
Last edit: by martin_csr.
82 kz250 weak no spark 27 Nov 2015 10:21 #700793
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2651
The ones that sell you a part are gambling on the fact most people just buy something else or go away. Paying for the return shipping can be a deterrent too.
82 kz250 weak no spark 06 Dec 2015 08:14 #702122
  • oldie
  • oldie's Avatar
I have simiilar problem , no spark but voltage at both sides of coil and at the cdi/ignition module. Not exactly sure what the mechanism is hat triggers the hall effect in the coil (such as areluctor and pickup). I replaced ignition module that came with bi,e due to its being opened and appeared sketchy (appearance of smal, crack in one of the pcb's inside). Got a supposedly working used one online.
Next???
82 kz250 weak no spark 11 Dec 2015 17:15 #702777
  • 82 kz250l
Have you tried everything that was mentioned?
82 kz250 weak no spark 20 Apr 2019 15:44 #802493
  • oldie
  • oldie's Avatar
Pretty much yepper even got a new direct replacement cdi still nuttin
  • Page:
  • 1
  • 2
