No spark stump the chump 19 Sep 2015 15:41 #690899
  • Topper
  • Topper's Avatar Topic Author
  • Thank you received: 133
No pickup transforms. Just points and a condenser.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
No spark stump the chump 19 Sep 2015 16:21 #690902
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
How does it run?
No spark stump the chump 20 Sep 2015 02:52 #690946
  • Topper
Steve,
It seems to be running just fine. So I'm not inclined to worry about it. I'm pretty sure it's done this as long as I've had the bike. I remember seeing it arc when I had the points cover off before.
I think the condenser just happened to fail while the bike was parked for a couple weeks. By the time I got it replaced the bike had been sitting for almost six weeks and was just being a bear to get started again.
Now that the new points and condenser are in it's running strong again. So I'm inclined to ignore the arcing across the points.
1979 KZ750 Twin
No spark stump the chump 20 Sep 2015 03:56 #690960
  • SWest
  • SWest's Avatar
  • 10 22 2014
I've noticed some sparks in the past. Couldn't see them unless it's dark. If there's fireworks, then the bike won't run for SHT.
Have a good ride. B)
No spark stump the chump 20 Sep 2015 06:34 #690983
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Even if it runs good now, I think your points faces will get pitted quickly, like putting a mini arc welder on them 50 times a second.
when you mount the plate , you have to be very careful to insulate the pickup transformers from any possible grounding
Check your plate mounting you can use a piece cardboard to test the theory..
Just use a cereal box and scissors and cut an Insulator to put behind the plate !
This sounds all wrong to me, the later transistorised ignition pick ups are insulated anyway.
