Regulator Rectifier 17 Aug 2015 09:04 #686074
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
That's a good illustration of measuring the system voltage drop directly.
By the way, the drop should not be zero, that would defy physics. :)
Regulator Rectifier 17 Aug 2015 15:34 #686120
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Regulator Rectifier 19 Aug 2015 11:54 #686379
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
kaw-a-holic
I'm going your way...what a great suggestion!
1982 KZ1100-A2
Last edit: by daveo.
Regulator Rectifier 19 Aug 2015 13:00 #686385
  • kaw-a-holic
daveo wrote: kaw-a-holic
I will get you some more picks on how I wired it in. For my 77, I ran new wires from the stator to the R/R. That's the 3 yellow wires you see coming from my R/R. Bat lead will go to my resetable breaker then to the bat. Negative will go straight to battery.
Jon
1977 KZ1000a1
Mesa, AZ
Regulator Rectifier 19 Aug 2015 19:20 #686435
  • daveo
  • daveo's Avatar
  • Premium Member
Nessism wrote: Sounds like a wiring issue. The stator should feed directly into the R/R. Bypass the factory harness. Output power from the R/R can feed into the fuse block, again bypassing the harness or tap the harness and look for voltage loss in the circuit. R/R ground should be to a solid frame point or direct to the battery. Don't trust the factory wiring, particularly with regards to grounds.
Well, I found what I think is the culprit...at least one of them.
The cheap (unused) stator I bought off ebay a couple weeks ago was just that. One leg would not register when I checked it on the bike earlier today. When I pulled it out and looked closely at it, I then realized why Genuine Kawasaki (stators anyway) is the best way to go.
On close examination, I'm reminded with 100% certainty why not to buy Chinese made parts for my bike. The junk stator looked pretty good when I installed it. :lol: Skimping on wire gauge thickness is a lousy place to cut manufacturing costs.
The old OEM Kaw stator I removed passed the ohm test, and I have a FA020AA Shindengen Mosfet regulator on the way.
So, here I go again...
1982 KZ1100-A2
Regulator Rectifier 19 Aug 2015 20:00 #686440
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2685
Oh man, you should have bought the SH-775. It's a series R/R, the FH family units are shunting R/R's. Oh well though, you should be okay. Hope you got a good price.
Regulator Rectifier 19 Aug 2015 20:34 #686445
  • daveo
  • daveo's Avatar
  • Premium Member
Nessism wrote: Oh man, you should have bought the SH-775. It's a series R/R, the FH family units are shunting R/R's. Oh well though, you should be okay. Hope you got a good price.
:huh: :blink: :S :pinch:... :unsure: :unsure: :unsure:
$47.50 shipped:
:unsure:
1982 KZ1100-A2
Last edit: by daveo. Reason: status update
Regulator Rectifier 29 Aug 2015 23:37 #687783
  • daveo
  • daveo's Avatar
  • Premium Member
I'm pleased with the results :) ...
1982 KZ1100-A2
Regulator Rectifier 30 Aug 2015 08:12 #687810
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
China strikes again. :angry:
Regulator Rectifier 30 Aug 2015 13:27 #687882
  • daveo
  • daveo's Avatar
  • Premium Member
swest wrote: China strikes again. :angry:
:cheer: Strike three...out of here!!! In the dumpster, buried under a pile of sawdust...good riddance. :evil:
1982 KZ1100-A2
Regulator Rectifier 30 Aug 2015 16:13 #687913
  • SWest
  • SWest's Avatar
  • 10 22 2014
I'm still pissed about choppers falling out of the air. :angry:
Regulator Rectifier 31 Aug 2015 16:04 #688088
  • FNGCOC
  • FNGCOC's Avatar Topic Author
  • Thank you received: 0
Sorry for not being able to follow through sooner everyone. It took 2 weeks for me to receive my parts!
Then, of course, it took a few days to get to, then recheck, then some little road tests here & there, but anyway, the bike is fixed.
I've gone out on a couple 100-200 mile day trips & it's back to a daily rider again now for 2 weeks.
Nessism, the SH-775 is working just great. I bought the Triumph lead kit & just spliced into the factory harness with bullet connectors.
The only modification needed was slightly longer mounting bolts.
Thanks again everyone. All help is much appreciated
