  • Page:
  • 1
84 left controls on 1983 KZ1100 wires for clutch s 30 Jun 2015 03:38 #678805
  • 76KZ900
  • 76KZ900's Avatar Topic Author
  • Thank you received: 5
I have a 83 KZ1100 and I bought both handlebar controls off off ebay dirt cheap in like new condition. Throttle side was plug and play. Left side appears to have 3 wires for clutch switch where my 83 only has 2 wires. Other than that controls are identical. Anyone know which two wires need to go to clutch switch and what third wire is for? Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
84 left controls on 1983 KZ1100 wires for clutch s 30 Jun 2015 05:34 #678811
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
By any chance do you know what model the clutch switch is from? Maybe it had a side stand switch. ???
I don't know much about it, but the EN450 wiring diagram shows the side stand & clutch switches wired thru a diiode device. When the clutch lever is pulled in, the circuit is completed between black & yellow/black (ground); the extra wire is black/red.
Last edit: by martin_csr.
84 left controls on 1983 KZ1100 wires for clutch s 30 Jun 2015 05:49 #678813
  • 76KZ900
No I don't. The owner must be parting out complete 84 KZ1100 but I don't know anything other than it had 7,000 miles.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
84 left controls on 1983 KZ1100 wires for clutch s 30 Jun 2015 07:13 #678825
  • martin_csr
The 84 ZN1100 has a junction box with a diode device, instead of the old-style fuse box found on the 83 1100. The extra wire probably had something to do with the diode as part of the starter lockout stuff. just a guess.
If the wire colors are the same as the EN450 & they probably are, then I'd try it without using the red/black wire.
  • Page:
  • 1
