GPz750 R1 charging problems
- Tyrell Corp
09 May 2015 19:48 - 09 May 2015 19:59
I've been sorting out my GPz750 R1 and discovered a charging fault. I'm posting it here if it is any use to other members.
The bike was used very rarely and only a few short journeys only, the battery was shared with another bike so I hadn't noticed it.
Firstly I put a voltmeter across the battery and was getting nothing above battery volts even with it revved up past 4k rpm...definite problem needs investigation.
First thing I noticed was a wire on the regulator/rectifier unit block connector that had gone awol.
Result! problem found... Just remove the old conector in the block and crimpa new terminal on the red/white. Note tool used to extract the pins out of the connector - a small screwdriver works too.
I thought that would fix it...unfortunately not.
Checking the three yellow output wires for resistance between each other and I'm getting open circuit - it should be less than 1 Ohm. Pulling the left hand alternator stator cover off and one mangled bolt drops out.
Which has trashed the stator
the rotor was undamaged, but that stator is shafted.
totally stuffed
Ok so new stator time. Can't easily find one for a GPz750R1 but managed to get one from a GT750 shaft drive. Just ran a tap through the threads of the casing which were blocked up.
Then new m6 bolts with threadlock -don't want this stator going the same way as the last
Getting a decent resistance reading now between all the three output tails
and getting well over battery voltage with engine running
and at 4000 rpm getting around 14.5 volts.
Sorted for a £10 used stator from ebay and one crimp terminal . Result !
Attachment 143122306677882.jpg not found
Attachment 1431223066778821.jpg not found
Attachment 1431223066778824.jpg not found
Attachment 1431223066778822.jpg not found
Attachment 1431223066778825.jpg not found
totally stuffed
Attachment 1431223066778826.jpg not found
Attachment 1431223066778827.jpg not found
Attachment 1431223066778828.jpg not found
Attachment 1431223066778829.jpg not found
Attachment 14312230667788210.jpg not found
Attachment 14312230667788211.jpg not found
Last edit: 09 May 2015 19:59 by Tyrell Corp.
- missionkz
Re: GPz750 R1 charging problems
10 May 2015 01:25
Bada Bing!! Great electric trouble shooting.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
10 May 2015 06:39
Good job! I know you are VERY happy to have nailed that problem! Ed
- loudhvx
10 May 2015 14:45
Nice! great photos!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
