KZ1000 WIRING HELP
- wack01
KZ1000 WIRING HELP
17 Nov 2014 11:53 - 17 Nov 2014 11:58
Hi I have a 1983 CSR 1000 and need some wiring help , it's a project.
I didn't have an ignition so I jumped the wires. Hopefully right???????
Here's the wires I jumped at the ignition connector.
White+ White/Black
Orange+ Orange/White
Brown+ Yellow/Red (from the start button)
Red (not connected)
Also I have a wire from the starter solenoid that I don't know where it goes.
From Starter solenoid>Red/White > black Fuse Box 2ea 10amp>spilt\ to White/Blue>Harness
.............................................................................................................. \ to White/black to ??????
Now I confirmed 12v at connections and nothing, is there some sort of tip over sensor? My harness is hanging.
I checked the fuses they're okay.
I circled on the diagram where these terminate, but I don't know what they are I don't have full manual.
I get nothing by pressing the start button, I also jumped this to make sure it was functioning.
White+ White/Black
Red (not connected)
Attachment Kz1000Help.jpg not found
Attachment IMG_20141117_113437.jpg not found
Attachment IMG_20141117_113247.jpg not found
Attachment IMG_20141117_113220.jpg not found
Last edit: 17 Nov 2014 11:58 by wack01.
- !Seymore
- Ride on...
Re: KZ1000 WIRING HELP
17 Nov 2014 22:19wack01 wrote: Hi I have a 1983 CSR 1000 and need some wiring help , it's a project.
<<snip>>
Welcome...
Did you pull in the clutch, or bypass the clutch switch, while hitting the starter button?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- wack01
18 Nov 2014 11:17
Well I tired again today and jumped the clutch and start button and it turned over.
Thanks for the help, but I would still like to know where those other wires go.
18 Nov 2014 13:02 - 18 Nov 2014 13:05
I think 81-82 are the only years for the 1000-CSR.
There aren't any diagrams for an 83 model at Partzilla.
Here's a Kawasaki wiring diagram for the 1982 KZ1000-M2 (CSR).
It's bigger if you open the image in a new window, then click on the new image to zoom in.
It's a pretty good diagram.
Last edit: 18 Nov 2014 13:05 by martin_csr.
- wack01
18 Nov 2014 21:31 - 18 Nov 2014 21:31
Thanks got it running compression was a little low, but it been sitting for 22 years. I'm going to soak the cylinders and PB blaster and let it sit for a couple of days, hopefully it will loosen the rings. I will follow with Seafoam to burn off any corrosion on the valves.
Last edit: 18 Nov 2014 21:31 by wack01.
- wack01
