Spark plug 18 Sep 2014 05:39 #647920
  • koloj
  • koloj's Avatar Topic Author
  • Thank you received: 5
Spark plug on cylinder 2 closing what the cause of that and fix
Re:Spark plug 18 Sep 2014 05:40 #647921
  • koloj
1980 kz750 h1
Re:Spark plug 18 Sep 2014 06:22 #647925
  • koloj
Oh and rebuilt engine new rings and handed and vales seated and clearances check twice
Re:Spark plug 18 Sep 2014 07:10 #647932
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2684
The only way the spark plug clearance could be closing down is if the piston is smacking it. Not good. You might want to check the other plugs to see if the same thing is somehow happening.
Spark plug 18 Sep 2014 07:10 #647933
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
  • Thank you received: 62
spark plug "closing" ? The gap closing up? You are going to need to be a little more concise to get a useful response!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Spark plug 18 Sep 2014 07:13 #647934
  • KzJim
  • KzJim's Avatar
  • Thank you received: 4
koloj wrote: Spark plug on cylinder 2 closing what the cause of that and fix
What? :huh:
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
The following user(s) said Thank You: Grumpy Ole Artist
Re:Spark plug 18 Sep 2014 07:44 #647937
  • koloj
I gap the spark plug then install it run the bike for 5 mins and gap is gone closed only on cylinder 2
Re:Spark plug 18 Sep 2014 07:45 #647938
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Do you mean it's not firing or not sparking?
Last edit: by martin_csr.
Re:Spark plug 18 Sep 2014 07:48 #647939
  • koloj
Like metal tang on the spark plug touching middle of the plug closed not completely flat closed just like if was bent down
Re:Re: Spark plug 18 Sep 2014 07:49 #647941
  • koloj
Like this
Spark plug 18 Sep 2014 08:14 #647945
  • dkoz
  • dkoz's Avatar
  • Thank you received: 17
Are they the correct plugs?
#2 not assembled correctly
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
Re:Spark plug 18 Sep 2014 08:28 #647948
  • koloj
What kind of spark plug do u use
