  • Page:
  • 1
  • 2
Won't turn over no sounds 25 Aug 2014 11:46 #645097
  • Alijaj805
  • Alijaj805's Avatar Topic Author
  • Thank you received: 0
Hey guys I'm new to the motorcycle world this is my first bike. It ran when I got it then just stopped cranking over. It's a 83 kz750 I get power and all but the starter doesn't turn nor do I hear any relays and I'm not exactly sure how to test the solenoid switch for the starter. Any help will be appreciated thank you ahead of time :)
Won't turn over no sounds 25 Aug 2014 12:59 #645109
  • Thank you received: 2829
Are you pulling in the clutch lever when you try to start it?
Is the "kill" switch in the "RUN" position?
Have you checked the fuses?
Won't turn over no sounds 25 Aug 2014 13:31 #645111
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
After you've done everything 650ed said & every thing checks out
Try wiggling the plug for the wires attached to the clutch perch
Won't turn over no sounds 25 Aug 2014 13:53 #645114
  • Alijaj805
It is on run and I checked all fuses. And what do u mean by clutch perch? All wires seamed fine even the clutch switch and it's in natural
Won't turn over no sounds 25 Aug 2014 14:16 #645116
Once more.........
When you tried to start the bike did you pull in the clutch lever (that's the handle thingy on the left side of the handlebars that you pull in to shift gears) ???
Won't turn over no sounds 25 Aug 2014 14:16 #645117
  • pete greek1
The starter lockout switch located on the clutch handle
Won't turn over no sounds 25 Aug 2014 14:23 #645118
  • Alijaj805
Yes I'm pilling the clutch leaver . I also wonder does it connect those two wires or disconnect them to let the starter engage
Won't turn over no sounds 25 Aug 2014 15:00 #645121
It connects them. Ed
Won't turn over no sounds 25 Aug 2014 15:03 #645122
  • Alijaj805
Ok we'll It did nothing is it possible that it's the starter solinoid doing this? I literally don't hear anything when I try and start it
Won't turn over no sounds 25 Aug 2014 15:19 #645124
I saw that you checked the fuses, and I'm not trying to second guess you, but if you have the glass tube fuses you may want to check them again. Here's why - Sometimes the filament inside the tube is perfectly fine and not burned, but one end of the filament will break free from the end cap due to vibration and age. When this happens the fuse looks perfect even though it will not conduct electricity. This can be checked using a meter or by trying another fuse in its place. I had this happen to me a good distance from my home, and I stumbled onto the the solution (spare fuse) through pure desperation. Ed
Won't turn over no sounds 25 Aug 2014 15:23 #645125
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
A battery cable could have come loose at either end, or the battery could be fried.
Won't turn over no sounds 25 Aug 2014 15:24 #645126
  • Alijaj805
Ok ima be headed home soon and ima check it again and swap out fuses and such I appreciate the help will post back ASAP
  • Page:
  • 1
  • 2
