KZ Power Outage
- Dasant
KZ Power Outage
22 May 2013 00:42
I took my KZ1000 out for a 20 mile ride this past Sunday. The weather was not the best and there was a light mist of rain coming down for at least 50% of the ride. When I came home, I parked the bike in front of my shed. I left the bike idling while I opened the doors then proceeded to check my turn signals, which were fine. I wanted to put away my gloves instead of putting them back on just to pull the bike in the shed. So I turned and started to walk toward the shed and the bike stalled. I thought it just stalled because the idle went too low. However, when I tried to start it I realized that the neutral indicator light was not on and after making sure the bike was in neutral, I found that the bike had no power at all. I subsequently checked the battery and fuses and they are all fine. Has anybody ever had this happen to their KZ and what did you find caused the problem?
- ramtough_63
Re: KZ Power Outage
22 May 2013 00:46
I am as we speak trying to figure out a similar situationm no power anywhere all fused good
mine is either wiring in headlight or switch (assuming)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- MFolks
Re: KZ Power Outage
22 May 2013 00:50
How old are the fuses? I make a note of replacing the glass tubed fuses on my bike once a year, as current surges will weaken/break the fuse element, making it unreliable. The stock fuses are AGX in size, available at most auto parts stores and boating supply places.
The following user(s) said Thank You: Dasant
- Dasant
Re: KZ Power Outage
22 May 2013 00:57
Did yours cut out suddenly too? I am just glad it waited to go when I was already home.
- Dasant
Re: KZ Power Outage
22 May 2013 01:00
The fuses are probably original, but I switched them out with spare fuses and checked them all with a test light and they all conducted electricity.
- bountyhunter
Re: KZ Power Outage
22 May 2013 02:56 - 22 May 2013 02:59
Could be a fried battery. The bike runs on the alternator until the RPMs drop and then the battery has to run it. If the battery can't handle the load, the bike dies.
Could also be bad battery connections, ignition switch, harness connectors. Anywhere the main power comes into the circuitry.
The ignition switch failed on mine and it was just like yours: running fine then suddenly stone dead coasting to a stop with no power or lights.
Last edit: 22 May 2013 02:59 by bountyhunter.
- bountyhunter
Re: KZ Power Outage
22 May 2013 02:57They should all be replaced anyway.Dasant wrote: The fuses are probably original, but I switched them out with spare fuses and checked them all with a test light and they all conducted electricity.
- Dasant
Re: KZ Power Outage
22 May 2013 22:31
I am thinking it is probably the ignition switch - since your bike had the symptoms. Also the switch has been a little quirky since I got the bike. If I turned it straight up everything was fine if I went all the way to the right the bike would cut out. What is supposed to happen normally when the key is all the way to the right at the third setting anyway?
- Motor Head
Re: KZ Power Outage
22 May 2013 22:43
All the way to the right on your ignition switch should be the Parking Lights setting.
Have a Look in "File Base" here on KZR, upper right hand corner of the page in the Tool bar. Look under your model for a wiring diagram. It should be there.
So you have Power with a Test Light across the Main Fuse? So then you should have power up to the connector at the ignition switch, white wire.
One fellow member had a loose connection in the headlight bucket, and another near the battery to fuse panel red/ white connection.
- Dasant
Re: KZ Power Outage
27 May 2013 22:46
I would like to thank all of the members who responded to my post. I would like to also update them on the resolution of my electrical problem. It was the ignition switch! I replaced the ignition switch today and the power came back! I would also like to thank Z1 Enterprises for the fast processing and shipping of my order. I ordered the part on May 23rd and the had a box on my doorstep by May 25th - using USPS Priority mail!
