79 kz650 d2 bare bones wiring diagram
- Koze
14 Mar 2013 20:26
Making first attempt to rewire bike and it would be a lot easier with with a "bare bones" kz650 d2 specific diagram. If anyone could help that'd be great. I've got the Clymer manual with wrong color wires in their diagram compared to my bike and have downloaded countless other diagrams and such. Thanks
1979 KZ650-D2
- wireman
Re: 79 kz650 d2 bare bones wiring diagram
14 Mar 2013 21:20
If you still have your stock harness attached id just start by removing things you don't need and go from there
![:) :)](/media/kunena/emoticons/8.png)
- Koze
21 Mar 2013 18:18
The harness is long gone
1979 KZ650-D2
- MFolks
21 Mar 2013 18:51
This might work for your bike, if not, maybe "Loudhvx" can make a diagram for you:
www.kzrider.com/forum/4-electrical/17274...t?limit=20&start=200
- loudhvx
22 Mar 2013 15:03 - 22 Mar 2013 15:12
If you are going to re-wire it, and you think you may use a Dyna S in the future, now would be a good time to convert to 3-phase charging system. That means a 3-phase stator and 3-phase combo reg/rec.
Do you have a link to the diagrams you are using? I don't recall seeing major inconsistencies on 1979 Kz650 D2 diagrams (there are often minor ones). Is there a chance your bike is something other than a 79 KZ650 D2 ? Or are you saying someone else re-wired it once already?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 22 Mar 2013 15:12 by loudhvx.
- Koze
27 Mar 2013 13:32
Just trying to get it running at this point. Made some progress but now when I hit and let go of starter button it wont stop trying to start unless I hit the kill switch
1979 KZ650-D2
- Koze
- Old Man Rock
06 Apr 2013 09:35 - 06 Apr 2013 09:47
:blink: .... This is a momentary switch design so you must have something not wired correctly...
Probably best you insert and post your wiring diagram you used...![;) ;)](/media/kunena/emoticons/11.png)
1977 Bare bones KZ650-B1...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 06 Apr 2013 09:47 by Old Man Rock.
- Koze
06 Apr 2013 12:04
Going back and forth between these
Attachment KZ650-D2.jpg not found
Attachment Custom_Motorcycle_Wiring_Diagram_by_Evan_Fell.png not found
1979 KZ650-D2
- loudhvx
06 Apr 2013 13:01
Here's a link to a 1979 KZ650D2 bare bones.
kzrider.com/forum/4-electrical/172746-19...t?limit=20&start=260
Scroll down to post #511882.
It's a KZ650 D2 for Rhoades.
1981 KZ550 D1 gpz.
Other links.
Other links.
The following user(s) said Thank You: Koze
- Koze
06 Apr 2013 20:36
Thanks very much. I'll let you know if it all goes well
1979 KZ650-D2
- Koze
09 Apr 2013 11:44
loudhvx you're a life saver. You sure did put a smile on my face
1979 KZ650-D2
