Dyna S Ignition Coil Compatability
12 Jan 2013 23:50 #567059 by NakedFun
Dyna S Ignition Coil Compatability was created by NakedFun
All,
Looking for the answer to two questions:
1. Which of the Dyna coils can I use with my Dyna S ignition on my KZ900?
2. Is there any advantage or disadvantage to running the Blue (.7 Ohms) Dyna coils on a street bike?
Any help would be appreciated.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • 4TheKZ1000
  • Visitor
12 Jan 2013 23:59 - 13 Jan 2013 00:13 #567061 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Dyna S Ignition Coil Compatability
Green / teal.....3.0ohm
Last edit: 13 Jan 2013 00:13 by 4TheKZ1000.
13 Jan 2013 00:08 #567064 by loudhvx
Replied by loudhvx on topic Dyna S Ignition Coil Compatability
NakedFun wrote: 2. Is there any advantage or disadvantage to running the Blue (.7 Ohms) Dyna coils on a street bike?
Disadvantage is that you will burn out your Dyna S.
13 Jan 2013 00:11 #567066 by NakedFun
Replied by NakedFun on topic Dyna S Ignition Coil Compatability
So the only coils that are compatible are 3.0 Ohm Green Coils or Stock Coils. Got it, and thanks. Wish the Dyna S literature made that statement.
Cory
1976 Kawasaki KZ900
13 Jan 2013 00:14 #567067 by loudhvx
The literature, or the website, should say that somewhere that 3.0 ohms is the lower limit for coil resistance. Anything higher is fine.
  • 4TheKZ1000
  • Visitor
13 Jan 2013 00:15 #567068 by 4TheKZ1000
stock are to low 2.4ohm If I rem right.....stock wont work.
13 Jan 2013 00:22 #567071 by NakedFun
Well they say the Dyna S is a drop in replacement for the stock points plate, so I would think that they work with stock coils. In addition, I can't find anything in the Dyna literature that says I have to use 3.0 Ohm coils, but I agree I think I have to. The funny part is, at Z1 Enterprises they sell the 3.0 Ohms Mini Dyna coils, but it SPECIFICALLY states they are not to be used with the Dyna S ignition as you will burn them out. Interesting. Either way, I'll order up a set of green coils.
Cory
1976 Kawasaki KZ900
  • 4TheKZ1000
  • Visitor
13 Jan 2013 00:28 #567072 by 4TheKZ1000
Call Dyna and ask....then you know its right....this subject has come up 100 times and Dynateks old web site said 3.0.....but they could have changed the Dyna-S to work stock.....I would just ring them to see since new coils are $160
Good luck....report back.... B)
13 Jan 2013 00:29 #567073 by NakedFun
I did just find this statement I happen to read over in the Dyna S installation instructions: "It was designed for use with stock, or other coils, or combination of coils that have at least THREE OHMS of primary resistance."
In addition, the whole mini coil thing appears to be due to dwell control compared to a standard wound coil. You need an ignition with separate dwell control to prevent them from operating improperly.
Cory
1976 Kawasaki KZ900
  • 4TheKZ1000
  • Visitor
13 Jan 2013 00:31 - 13 Jan 2013 00:32 #567074 by 4TheKZ1000
If you look down the list to dyna-s it says 3.0
www.dynaonline.com/skins/products/accessories/Dyna_Coils/
DYNA S (non-Harley):
Recommended - DC1-1. Use coil with 3.0 ohms primary resistance
Last edit: 13 Jan 2013 00:32 by 4TheKZ1000.
13 Jan 2013 00:31 #567075 by NakedFun
Need to buy the green 3.0 Ohm coils... I appreciate the help.
Cory
1976 Kawasaki KZ900
13 Jan 2013 00:34 #567076 by loudhvx
Stock electronic ignition from Kawasaki uses 2.3-ohm coils, which are too low for the Dyna S.
The stock, points coils are 4.0 ohm, which work fine with the Dyna S.
Page one of the instructions:
You can't use the mini coils on ignitions with fixed dwell. They require ignitions with variable dwell angle so the coils don't overheat.
