2 wire stator vs 3 wire 30 Dec 2011 18:23 #495334
  • Flyndrive
  • Flyndrive's Avatar Topic Author
  • Thank you received: 4
The flywheel looks good and no wobble. I think the magnets are strong they usually pull the stator and cap right into place.
Thanks for the measurement. Now I'll just have to look fOr the regulator and stator.
1980 KZ 550A1
1985 GPZ 900R
2 wire stator vs 3 wire 30 Dec 2011 18:42 #495338
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
You can also get aftermarket stators which are sometimes asvertised as "heavy duty", meaning more output. The one from "Rick's" gets good reviews. It's about $120 - $130 at Old Bike Barn and Dennis Kirk.
Also, in case you haven't seen one, you can spot the 3-phase stators easily because they will have 3 wires and 18 "spokes", whereas your 1-phase has 12 spokes.
Last edit: by loudhvx.
2 wire stator vs 3 wire 04 Jan 2012 19:34 #496330
  • Flyndrive
Found a 3 phase stator, flywheel, and reg/rec on eBay from a 83 KZ550. Hopefully that will solve my problems. Just have to wait for them to get here.
1980 KZ 550A1
1985 GPZ 900R
2 wire stator vs 3 wire 04 Jan 2012 19:43 #496333
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
You might want to do this:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
2 wire stator vs 3 wire 07 Jan 2012 15:16 #496919
  • Flyndrive
I got my new (used) 3 phase stator in last night, so I spent the morning installing it. Swapped out the Reg/Rec, figured out the new wires and where they came from or went to. Had a couple extra wires for things like the kickstand switch, so I removed them and retaped the wires that were left. Figuring out the wires really wasn't hard, just match up the colors, some of the connectors had to be changed out, but no problem.
Got it all back together, started the bike. Hooked up the voltmeter while it was warming up. The voltage at idle was right at 12v. Brought the RPMs up to 2k and the voltage came right up over 13v. With the RPMs at 4k the voltage came up to 14.5v or so and stayed. Looks like it fixed the problem of not charging very well.
Thanks everyone for your help.
1980 KZ 550A1
1985 GPZ 900R
2 wire stator vs 3 wire 07 Jan 2012 20:21 #496955
  • loudhvx
  • loudhvx's Avatar
Good to hear that it bolted right in.
Thanks for the update and confirmation... will have to make a note of it for the future.
Keep an eye on it, though. One of the failure modes of the reg/rec is that it will seem to work at first, but on a sustained highway run at higher RPMs, it will slowly drop voltage. After an hour or so the battery is pretty drained. I only mention it because I assume you bought a used reg/rec.
2 wire stator vs 3 wire 08 Jan 2012 00:16 #497005
  • Flyndrive
Yes it was used. It was off an 83 KZ550. I think an H1 model. All he parts were very clean. Also replaced the starter solenoid just cause I got a package deal. It came with the flywheel, but it was the same so I just used mine.
I was thinking of trying to put a voltmeter gauge on the bike but I dont know where I would mount it.
1980 KZ 550A1
1985 GPZ 900R
2 wire stator vs 3 wire 02 May 2016 21:00 #724202
  • Derekforeal
  • Derekforeal's Avatar
  • Thank you received: 0
So my stator just went on my 1980 kz550.
Ordered a new one and it came a 3 wire.. i guess the 2 wire are old news! My question is do you have to replace the reg/ rectifier. Or is it possible to just use 2 of the 3 wires on the new stator?
2 wire stator vs 3 wire 03 May 2016 06:51 #724236
  • loudhvx
  • loudhvx's Avatar
Using 2 of 3 stator wires will probably not provide enough power.
You will need a 3-phase reg/rec. This will also require you to run one extra yellow wire from the new stator to the new reg/rec. You can use 18ga wire for that, 16ga if you are worried about current.
You can get very cheap, yet reliable, used reg/recs from mid 2000's Ninja 250's or 500's. They bolt right up (in place of an original 3-phase reg/rec, I think your 1-phase had the same bolt pattern). The wires may need to be spliced, but the colors match up correctly.
You can also try a series reg/rec. Ed Nessism has details on that.
Just curious, how did your 1-phase stator go belly-up?
2 wire stator vs 3 wire 03 May 2016 12:16 #724291
  • Derekforeal
Well i can find new regulators/ rectifier on amazon for $20 so it not too expensive. But i jut have plans on selling the bike so didn't want to put too many parts into it.
I was driving down the highway and then had sudden power loss. Like lights cut off completely, so I down shifted and let out the clutch and she still wouldnt start while rolling.
I put a brand new battery in it last fall and it won't keep a charge so assuming it's got to be the stator.
2 wire stator vs 3 wire 03 May 2016 12:40 #724299
  • Thank you received: 2829
I don't understand why you would assume it's the stator. The problem could be the stator, but it just as likely could be the battery , wiring, rectifier, regulator, fuses, dirty or loose connectors, etc. I recommend you run the simple tests that are described in the Kawasaki Service Manual so you can identify the true source of the problem. That could save you a lot of time and money compared to throwing parts at it hoping you will get lucky. Ed
2 wire stator vs 3 wire 04 May 2016 22:03 #724646
  • Derekforeal
Very true. It was just really odd for my bike to be completely fine a few weeks prior. I drove it a half an hour to my new house without a hiccup. Then it kept dying whIle it was running as if the power was suddenly un hooked. Could you please list or send me a reference to the tests I can perform from the kawasaki service manual?
