Starting My Z1 is Making Me Bald!!
- johnskzs
Secondly, I have posted a pic attachment #2. It is showing a plug, tan in color. If a small screw driver is inserted next to the black wire, the bike starts. When the screw driver is removed, the bike won't start. With a test light, the light won't light when pushed into the female part of the plug. Can anyone figure this out?
- Motor Head
- Thank you received: 391
2nd pic, I can't see the wire color, but you need to pull the connector and inspect. Probably bad terminals, is this from your wire short that was blowing fuses? most likely.
- Thank you received: 2098
www.kzrider.com/filebase/doc_download/262-z1ab-us
The connection inside the plug may be too loose without the screw driver in there holding things tighter.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Most likely - as already said here - its just a matter of the contacts being waorn/loose/dirty and the screwdriver is just pressing them together.
Pull ALL the electrical connectors apart on the bike one by one. Properly remove each little pin connection from each connector and scrub them clean with a toothbrush and a reputable elctrical contact spray. Crimp them slightly more closed before re-assembly to make the connection nic and tight.
Shouldnt take more than a few hours and will save alot of headaches.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Patton wrote: The connection inside the plug may be too loose without the screw driver in there holding things tighter.
+1 from me too. Either the wire itself is loose in the connector, or the connectors are loose in the plug (plastic housing). Should be a fairly easy fix either way.
EDIT: If it's the same as my bike, the only black wire I can think of is the one that comes from the start button to the starter solenoid. Could be why you are having issues in this department. (also the 1/4 coil wire on mine...but my guess is the start button wire)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- MFolks
- Thank you received: 540
- Thank you received: 2829
www.hvccycle.com/electrical-connectors.html
vintageconnections.com/
- johnskzs
- johnskzs
- johnskzs
- johnskzs
I been trying to get this stupid bike started for 3 durn years and if a screwdriver will finally git 'er done....well, what can I say!!! LOLOLOL Hey thanx for your info. I am going out to work on the bike today and will post back later on update.
- Thank you received: 797
